Power Trac Draft Control
   / Power Trac Draft Control #1
duane
Toro 266H and PT422
Just curious to see how many of you guys that are operating the 1430 and bigger units, are using draft control. It seems like it would be a nice feature. It would seem especially useful when plowing etc in float when the tractor arms ride over the implement. How does Power Trac accomplish draft control. Do they use special valves, I’ve never seen a schematic or narrative on how draft control is hydraulically accomplished. Think it can be added to the 422 or 425 models.
Duane
   / Power Trac Draft Control #2
I find draft control essential. If I do not have it engaged and properly adjusted I do not have adequate traction on my steeper slopes (23-30 degrees).
On the 1845 the hydraulic take-off is from the variable displacement pump. The amount of pressure (lift) provided to the loader lift cylinders is controlled by an adjustable pressure valve.
2007 WABASH 53FT DRY VAN TRAILER (A51222)
2007 WABASH 53FT...
2000 WINNEBAGO FORD F550 RV (A50854)
2000 WINNEBAGO...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
377811 (A48836)
377811 (A48836)
2015 Chevrolet Tahoe SUV (A50324)
2015 Chevrolet...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A51039)
2000 John Deere...
