Power Trac Lube
   / Power Trac Lube #1
Charlie_Iliff
Veteran Member
Arnold, MD
Power Trac PT1845, John Deere 2240, John Deere 950, John Deere 755, Jacobsen Turf Cat II
After a bunch of snow plowing, my PT1845 developed a rusty-hinge type creak when turning. I hadn't been particularly religious about lube intervals, so when the noise started I greased everything, oiled all the ball joints, etc. , with no change in the creaking. Terry, at Power Trac immediately suspected the ball end(s) on the steering cylinders, as did Sedgewood, but I had sprayed oil on them with no effect, and had even taken the cylinders loose and articulated the machine by hand to verify that the noise wasn't in the center joint.
After a couple more oil applications, and a bunch of inconclusive diagnostic hydraulic tests, including sticking the bucket in a snow pile and sliding the front back and forth with the steering, the noise went away.
My current working theory is that Terry and Sedgewood were right all along. It occurred to me in the middle of the night that if the ball joint were filled with water, oil would float on the outside and not change anything. It took some loading and turning to get a little oil actually inside.
If that theory is correct, it may make sense periodically to wash the ball joints with WD 40 to displace water, and then apply copious amounts of the lubricant of your [Power Trac's] choice.
Terry advised much more frequent lube than the book recommends. For the tilt mechanism, particularly, he says to give it a shot before use. That often isn't really necessary, but only takes 30 seconds. He has one in the shop now which bound up and bent.
The center articulation joint is particularly high load and constant use. That one also only takes a few seconds to hit with a gun, and may save pretty costly damage.
<font color="red"> Lube Rule: If some's good, more's better. </font>
   / Power Trac Lube #2
Charlie: <font color="red"> Lube Rule: If some's good, more's better. </font>
Today I took your lube advise to heart, lubed everything, and ten minutes later...
<font color="red"> After a bunch of snow plowing, my PT1845 developed a rusty-hinge type creak when turning </font>
Go figure! So I put my hand on the hydraulic reservoir to see if I could feel the creak. Nope. Then on the frame just forward of the center joint. Yup, quite strongly. Then on right steering cylinder barrel. Same. Then on left cylinder barrel. A bit stronger maybe? Ok, out comes the oil can again. Squirt again the left front cylinder ball. No change. Squirt the left cylinder rod and rear ball. Two steers and away goes the creak. Note how this dummy squirted both the cylinder rod and the rear ball! So now which was dry?
Sheesh,
Sedgewood
   / Power Trac Lube #3
I'm using white lithium spray grease for all the ball type ends and hit the cylinders occasionally. Are you guys doing things differently?
   / Power Trac Lube #4
<font color="red"> squirted both the cylinder rod and the rear ball! So now which was dry?
<font color="black">
My money is on the rear ball!
The cylinder rod is lubricated by the hydraulic oil in the cylinder. The seals wipe the rod clean. One of the problems with oiling the rod externally is that it will then collect dirt if it is not immediately wiped.
   / Power Trac Lube #5
this is something i talked to terry about,i asked him way they don't use grease fittings.he told it would drive the cost up,and spraying worked.a grease fitting pushes the dirt and water out,spraying traps it in .i don't think there is enough material to drill and tap for a zerk fitting.i think a small 1/16 hole with a slight taper on the out side and use a pointed grease end like on some u joints would work
   / Power Trac Lube #6
the same and more and more frequently in the snow ,slush and salt(chemicals)
   / Power Trac Lube #7
MossRoad: <font color="green">I'm using white lithium spray grease for all the ball type ends and hit the cylinders occasionally. Are you guys doing things differently? </font>
Bob999: <font color="green"> The cylinder rod is lubricated by the hydraulic oil in the cylinder. The seals wipe the rod clean.</font>
I used spray lube 'til the can stopped spraying then got out the oil can. This is the first time I oiled a rod but it sure looked dry. I tend to think the snow wipes it clean and the seals are too good to lube it enough to prevent the creak. I'm not sure about this but I had just lubed the rear ball before the creak. Now to get some lube free seat time so I can do a better test /forums/images/graemlins/tongue.gif
Sedgewood
   / Power Trac Lube #8
the rods on hyd.cyl.(1) don't need oil, the wiper ring will take it off (2)the rod should be chrome.this problem is common in the winter the grease will not go in with out heat.this is why you have zerk fittings, the pressure is needed. even with that we warm the gun up!there is grease made to be used under water,syn.grease is even better
   / Power Trac Lube #9
just one other thing,if would use lithium grease on the equip. we make a living with we would all be out of work.it's not made this application. it's better used on on hood and trunk hindges
   / Power Trac Lube
<font color="red"> just one other thing,if would use lithium grease on the equip. we make a living with we would all be out of work.it's not made this application. it's better used on on hood and trunk hindges
</font>
Johara1:
Got a specific lubricant recommendation for the spherical ends on the various cylinders, particular steering which is in the snow a lot? I have some spray lube of indeterminate ingredients which claims no solvents which I used last. Without grease fittings, liquid is the only choice, without pulling the pins and rolling the bearings around in grease.
2022 Patriot 10ft 3,500lb Enclosed Cargo Trailer (A45336)
2022 Patriot 10ft...
2014 UTILITY 53X102 DRY VAN TRAILER (A45677)
2014 UTILITY...
2007 PARK SEPARATOR (A47001)
2007 PARK...
2007 SAND SEPARATOR (A47001)
2007 SAND...
1.5in Galvinized Pipe (A47809)
1.5in Galvinized...
CAT 60in Bucket (A47809)
CAT 60in Bucket...
