Power Trac Tree Shear Mounting
   / Power Trac Tree Shear Mounting #1
pane056
Lake City, Michigan
CaseIH 685 & JD 3320
Hello;
I need to communicate with owner / operators of the PT Tree Shears. I looks like I'll be getting one soon. It will be used with a JD 3320 and 300CX loader. When I make a mount I don't know if it should be mounted to the Heavy Dutry Bucket or should it be mounted with the bucket removed.
Most likely I will use a 10 foot section of 3" pipe for an extension. It's primary use will be for pruning trees any tree shearing will be on small 3" - 4" Austrian pines and the same size poplar.
I sure would like to see some pictures of what other folks have done for mounting.
thanks, nicholas
   / Power Trac Tree Shear Mounting #2
Most likely the people on this forum use the PT quick attach that comes with it and fits on their PT. I suggest that in addition to posting here, you post on another section of TBN. You might try the attachment section. Good luck with this.
   / Power Trac Tree Shear Mounting #3
I'd think you would have a clearer field of view without the bucket. Other than that, it will probably work either way.
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
1996 NEW HOLLAND 3930 WITH LOADER (A51243)
1996 NEW HOLLAND...
2011 Ford F-150 Pickup Truck (A50323)
2011 Ford F-150...
2020 KUBOTA RTV...
Year: 2013 Make: Chevrolet Model: Caprice Vehicle Type: Passenger Car Mileage: 73,798 Plate: Body (A50324)
Year: 2013 Make...
John Deere 6410 Loader Tractor (A50514)
John Deere 6410...
