Power unit pully bearings were nearly dry
   / Power unit pully bearings were nearly dry #1
prs
Platinum Member
Logan, WV
JD 650, Ventrac 4500Z AJ02248
At about 750+ hours my original drive belt shredded into many itty-bitty pieces of cording and rubber. Must have come off the rear groove and tangled with the keeper. I had a spare and replacement on the 4500Z was a breeze, but I did get some extra clearance by removing three front grill fasteners on the right hand side. In the process, I rotated the unbelted pully and thought it a bit rough. I removed the pully to inspect the two ball bearings (KOYO-6305AS-ROM-049). These are cery common industrial "rubber" shielded ball bearings. The bearings with the pully in hand both felt smooth, but given the hours of hard use I deciced to remove a shield from each to inspect. The remaing grease was very sparce, black and dry. I did not press them out, but cleaned them with kerosine with just the outer sheilds off. Used compressed air to remove the kerosine. Then I repacked each bearing with shear resistent polyurea multipurpose grease before replacing the shields. This may be a chore to add to the maintenance list about every 500 hours or so. I have noticed DonnyBoy has a nice YouTube showing how to do this if you have not done before. A set of new bearings would probably be less than $25.00 or so US.
prs
2019 John Deere 5090E (A50120)
2019 John Deere...
P.T Industrial Cart (A50121)
P.T Industrial...
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2025 12V Diesel Pump, Hose And Nozzle (A50323)
2025 12V Diesel...
Fifth wheel multi use trailer. (A52748)
Fifth wheel multi...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
