inane2
- Joined
- Feb 26, 2012
- Messages
- 137
- Location
- Kentucky
- Tractor
- NH T4.75 Powerstar, Kubota KX161-3 & SVL75-2
Good evening guys,
Working on a 2012 NH PowerStar T4.75 tractor. There is a factory option for a little over $50 (retail) that adds an extra 12V power outlet in the lower right dash as pictured (pic taken through right door opening):
Opening is simply covered by a rubber plug:
I got on NH's part diagrams, located the outlet and picked it up for about $10:
I was kind of expecting this to be a "plug and play" type mod. Did some digging around in the dash and didn't find the connector for the extra outlet. I'm limited on my search because there are 10 HVAC vents and the duct work is kinda in the way. Checked my owner's manual and it only shows 1 fuse to protect what I'm assuming would be both outlets.
Talked with my dealer but the service manual for the T4.75 is outdated and the electrical diagrams are somewhat hard to interpret. I'm very familiar with using electrical and vacuum troubleshooting manuals but the T4 manual was hard for my to navigate. (I'll save my beef with NH over poor customer support and resources for this tractor for another post!)
I've looked over the wire harnesses on NH parts website as well. I can't imagine their being two different cab / dash harnesses based on if the tractor has the extra outlet or not.
I can hard wire this outlet but if the factory wiring is there, I'd prefer to use it. I want to install this outlet because it's in a convenient spot if your needing 12V out in the field and the tractor is parked.
Any fellow TBN members have any input or advice on hunting down the OEM connector?
Thanks!
Thanks!
