grayw0lf
Help!
I'm trying to test the hydraulic pressure on my Kubota L355SS, but I can't seem to get the pressure to register on the gauge. So, what am I doing wrong?
Per the manual: the feedback rod is unhooked, draft & control levers are all the way up. The gauge is hooked up to the test port in the 3pt cylinder cover. There is obviously pressure, or the loader & shuttle shift wouldn't work at all.
The linkage on the draft control is not hooked up (as when I bought it) & I do doubt the draft control works anyways.
The reason I'm testing is the loader is weak (have to rev high to lift anything over about 400lbs) & slow.
Thanks!
Thanks!
