Pressure testing radiator
   / Pressure testing radiator #1
liberty2701
Platinum Member
Lakes region,NH
Kioti Dk50se hst
I just started getting that sweet smell of antifreeze from the radiator area of my kioti dk50. There are no visible leaks and I checked all hose clamps. The rad is full and the overflow seems to stay at the same level. I would like to get a pressure test kit. Ebay has them for about 60 bucks. Any idea if these kits will work on a kioti radiator? Cap looks similar to my Toyota but they do not interchange. Any recommendation on a kit?
   / Pressure testing radiator #2
JMO...
If there are no physical signs of leakage...
I would replace the cap (or check the relief valve on the cap) before I would bother pressure testing...
If the cap is not holding the correct pressure it will release the "smell"...
   / Pressure testing radiator #3
Take a look around your water pump also.
JMO...
I like the cap idea. Everyhing is !00% dry including the water pump. I guess I should mention it has only 110 hrs on it. Not worth transporting to the dealer to have the cap checked under warranty. I wonder if Napa would have a new cap that interchanges?
   / Pressure testing radiator #5
If its under warranty, maybe the dealer will send you a new cap to try. I agree at those hours you shouldn't have any leaks.
Jim
   / Pressure testing radiator #6
A little advice on using a cooling system pressure tester. Start the engine and then hook up the pressure tester. While the engine is running check for leaks. Dis-connect the pressure tester and then shut off the engine. From experience if you do not have any idea where the leak is and it happens to be an internal leak that is into a cylinder, AKA head gasket that is leaking into cylinder and or intake gasket, you can hydraulic the engine if you leave the tester connected with pressure applied and you shut off the engine for even a short period of time. If the coolant leaked into a cylinder and you re-start the engine more than likely you will break the starter and kiss a rod good by. If it is an almost know leak such as an intake gasket that leaks externally and you just want to verify, then using the pressure tester will probably make the leak that much worst and or make it so you need to fix it right then. Just some info. Later.
I hydro-locked an engine once when I was a kid. Drove through a large puddle and bent two rods.. The smell is def coming from the fan area. I can get my head right in there with the hood up and smell it. I need to keep an eye on the overflow to see if keeps getting lower indicating a leak. Any idea what pressure test kit will fit the Kioti radiator?
   / Pressure testing radiator #8
One other thing I forgot to mention. You do not need to pump up the system to operating pressure. AKA 10/ 14 PSI. Generally you can detect the leak at much lower pressures say 2 to 7 psi. Later
   / Pressure testing radiator #9
Use a clean piece of approx 3/8" hose to extend your nose. It is safer than getting your face too close to moving parts and it will allow you to be more specific about where the smell is coming from. Sort of like a stethoscope for your nose.
Dave m7040
   / Pressure testing radiator #10
I have a Stant pressure test kit. Take a look at their website, the have many adapters available, and I have always been able to buy what I needed, for ATV, tractors, and what not.
It sometimes takes some work to find the right adapter. I try to find a stant part number for the cap replacement, then work from there.
1,000 Gallon Propane Tank (A49339)
1,000 Gallon...
John Deere 1210A Grain Cart (A49339)
John Deere 1210A...
2017 Genie GTH-5519 5,500LB 4x4 Rough Terrain Telehandler (A46683)
2017 Genie...
2025 76in Dual Cylinder Grapple Skid Steer Attachment (A49346)
2025 76in Dual...
2025 Kivel Quick Hitch Skid Steer Attachment (A49346)
2025 Kivel Quick...
John Deere CX Gator Bed (A49251)
John Deere CX...
