Pressure washing f/p 2425 with fel?
   / Pressure washing f/p 2425 with fel? #1
texman
Been working tractor around a little mud and would like to pressure wash it but wonder if anyone else pressure washes their machine? I'm a newby and want to keep my tractor clean if it doesnt present a problem washing it this way. Any advice would be appreciated!
   / Pressure washing f/p 2425 with fel? #2
Some say don't, but I do it occasionally. I don't use a straight stream, but a lower pressure fan spray nozzel. I also avoid shooting closely/directly at seals, dust boots, edges of case covers/gaskets, such as where the steering upper and lower portions go together or where the valve cover meets the cylinder head. I also avoid the end of hydraulic cylinders and grease fittings so I don't inject any water into the lubed areas. I also rubber band plastic bags over the hydraulic vents and air filter intake to keep water from finding it's way in those areas. I also avoid the radiator as it is a good way to destroy the cooling fins.
A pressure washer is a usefull tool, particularly at stripping away the mud, you just have to be carefull how you use it. I have been using them in this fashion on autos/trucks and other machinery for a long time now with no ill effects.
   / Pressure washing f/p 2425 with fel? #3
my brother pressure washed mine a couple months back, this was the resulting effect of somehow blowing the seal on the hyd pump which ended up costing close to 300 in repairs & down time so YA stay away from them with a heavy duty spray... it was leaking a bit & had dirt on the engine ect so away he went I still haven't gotten every thing back together 100% while washing wheels sheet metal and other parts are ok stay away from gauges, engine componets alt radiator ect... just my opinion
mark M
Thanks for the very good input. Will heed all.
   / Pressure washing f/p 2425 with fel? #5
I like to keep my tractor clean, though some others may find that amusing.
I warm up the engine a little, spray purple grease cutter (from any auto parts store) and then spray it down, engine and all.
It helps me cause I always know what needs attention, what is leaking, etc.
It only takes 5 minutes or so to do.
CRAFTSMAN ZERO TURN MOWER (A53843)
CRAFTSMAN ZERO...
Kubota SVL95-2 High Flow Cab Skid Steer (A55218)
Kubota SVL95-2...
PALLET MISC POWER TOOLS (A53843)
PALLET MISC POWER...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
Hose Reel (A53424)
Hose Reel (A53424)
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
