Price Check Price Check 2320 + SnowBlower + CX200 Loader + 54" Mower
   / Price Check 2320 + SnowBlower + CX200 Loader + 54" Mower #1
GOBOGIE
Michigan
2009 John Deere 2320
Ok guys I can't begin to tell you how much this site has helped me! A wealth of knowledge indeed.
Here is the initial quote I received from the dealer. I figure he is giving me about a 5.5% discount (is that right???):
2320 4-Wheel Drive Tractor
Code Description Qty List Price
0150LV 2320 4-Wheel Drive Tractor
Base Machine Suggested List Price Does Not Include $250 USD Destination Charge. $13,229.00
Options
Required Items:
1505 Standard Seat, Open Station 1 In Base Price
4400 23X8.50-12 6PR Front R4 Ind. Bias
12-16.5 6PR Rear R4 Ind. Bias 1 $114.00
Configuration Total: $13,343.00
200CX Loader
2511W 200CX Loader $2,850.00
Options
Required Items:
2000 Mounting Frame (2320) 1 No Added Cost
4020 Ballast Box 1 $206.00
5010 Hood Guard In Base Price
8000 49 In. (1250 mm) Materials Bucket 1 In Base Price
Configuration Total: $3,056.00
54D In. OnRamp Mid-Mount Side Discharge Mower (For 2320 Tractor)
0170LV 54D In. OnRamp Mid-Mount Side Discharge Mower $1,810.00
Options
Required Items:
1001 Attaching Parts (Mechanical Mower Lift)
For Independent Mower Lift, Code 1001 and LVB25630
Must be Ordered. 1 $346.00
Configuration Total: $2,156.00
47 In. Quick-Hitch Two-Stage Snow Blower
1473M 47 In. Quick-Hitch Two-Stage Snow Blower
BM20761 Hydraulic Coupler Kit Required on X700, X465, X475
and 425 Tractors.
Compact Tractors Require Dual Selective Control Valve and
Front Attaching Support Kit. See Sales Maual for Front
Attaching Support Requirements.
See Sales Manual for Ballast requirements. $2,050.00
Options
Required Items:
2007 Front Qiuck-Hitch and Hydraulic Lift $658.00
3008 2000 RPM Front PTO Kit (2320) 1 $238.00
4005 Implement Drive and Upstop 1 $347.00
Configuration Total: $3,293.00
Summary​
Equipment Totals (includes "Other Charges") Qty Each Extended
2320 4-Wheel Drive Tractor $13,343.00
200CX Loader $3,056.00
54D In. OnRamp Mid-Mount Side Discharge Mower $2,156.00
47 In. Quick-Hitch Two-Stage Snow Blower $3,293.00
Total Equipment Group Price: $21,848.00
Additional Charges
Freight: +/- $250.00
Setup & Delivery: +/- $300.00
Discounts: +/- ($2,898.00)
Trade In Allowance: +/- $0.00
Extended Warranty: +/- $0.00
Taxes: +/- $1,170.00
Total Additional Charges: ($1,178.00)
Total Delivered Price: $20,670.00
Just a few things more:
- I'm still on the fence on the 54" vs. the 62" MMM. I know a lot of you fellas highly recommend the 62" but I just think it's just too big for me???
- I'm still considering the 54' snow blower vs. the 47'. Again I'm thinking it might be too big for me. I don't have that huge of a drive :rolleyes:
Am I missing anything on the quote above???
Thanks In Advance,
Cory
   / Price Check 2320 + SnowBlower + CX200 Loader + 54" Mower #3
Thanks In Advance,
Cory
Go bigger on both - there will be too much wheel overlap if you don't.
   / Price Check 2320 + SnowBlower + CX200 Loader + 54" Mower #4
Your terrain should dictate your attatchment sizes in this instance. Especially the mowing deck, if your terrain is all relatively flat than bigger is better. If you have lots of mounds, rough terrain, etc the smalled deck can be more managable and will not have to rely as much on the gauge/anti scalp wheels to avoid scalping and wont have as much trouble with cutting to high on the opposite side. Horsepwer wise both blowers should be fine on this tractor i have seen numerous 48" blowers on this chasis of tractor and they work great. The 54" blower being new I have not seen work in heavy snow yet.
   / Price Check 2320 + SnowBlower + CX200 Loader + 54" Mower #5
There are folks that have a 47" blower on these ( not a 48") because that is all they offered at the time , I don't know of anyone that doesn't complain that the tractor is wider then the blower and thus the wheels pack down the snow, especially when turning. There are threads that talk about adding "wings" to solve this but why go through the trouble when a wider blower is now available?
As far as the 54" deck scalping less then 62", I don't know if that is a totally valid argument, I have owned both sizes and saw no significant difference unless cutting at an extremely low level. Besides what better way to flatten out all the high spots?;) What I like about the 62" is the extra width allows your to trim up close to things without risking rubbing the rear wheels.
Different stokes for different folks so buy what you want.
This reminds me of when I built my house and wanted to mount a flat screen TV over the fireplace; I asked my AV guy what he thought . His answer was "we can do what ever you want but I have taken down more TV's over the fireplace then I have put up". At first it sounds like a cool idea but in practice didn't work so well.
   / Price Check 2320 + SnowBlower + CX200 Loader + 54" Mower #6
I have the 62d deck on my 2320 and love it. This tractor will cut a tighter circle around trees than my 38" riding lawn mower!
"This reminds me of when I built my house and wanted to mount a flat screen TV over the fireplace; I asked my AV guy what he thought . His answer was "we can do what ever you want but I have taken down more TV's over the fireplace then I have put up". At first it sounds like a cool idea but in practice didn't work so well."
Not to change the post, but why didn't it work so well? I was contemplating this same idea.
   / Price Check 2320 + SnowBlower + CX200 Loader + 54" Mower #7
Two main reasons:
1. Heat rising from the fireplace would overheat the TV
2. After a while many people would find it tiring to look up to watch the TV.
Bobcat 14" Hydraulic Asphalt Plainer (A52384)
Bobcat 14"...
(4) 6 LUG GMC TIRES & WHEELS (A51248)
(4) 6 LUG GMC...
2015 DODGE RAM...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
Hitachi Zaxis 350 LC (A51573)
Hitachi Zaxis 350...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
