Comparison Price difference on NH TC40 and a TN55
   / Price difference on NH TC40 and a TN55 #1
Riding Tailboard
Daniels WV
NH TC-40da w/ 16L
Hello,
I am needing advice on tractor prices. My father has a NH TN 55 and I have a NH TC 40. I want to buy his and sell mine, and I want to give my father a fair price and ask a fair price for mine. I really like my tractor and only want to trade up because of the benefits of a utility tractor over a Compact. Both tractors are located in WV.
The 55 is a 2003 4x4 with FEL, 171 hours ,Tires filled, 1 rear remote, This tractor is like brand new
The 40DA is a 2006 4x4 with FEL, 560 hours , Tires filled, 3 rear remotes and hyd top link, This tractor shows a little wear but really good condition.
Please let me know what you think about their value. Also any opinions about the TN 55 would be welcome.
Andy
   / Price difference on NH TC40 and a TN55 #2
I like mine.
This is the same tractor as the equivalent TN-60/65/70 except that the front axle is lighter. There is an early version (square headlights, and a later version (dropped hood, molded headlights -- sort of tear drop). Also an early and late version of the loader brackets (the early ones tend to crack and the mounting bolts loosen up -- strip/break/hog out the threads). His probably has the loader remotes mounted under the deck/cab. Cab models can stack up to 4 remotes behind/under the cab, open models can stack 6~8. Exhaust can stick up out of the hood (early ones tended to burn the paint on the hood), or under the deck/cab. Trans could be 4 hi/lo, 4/hi/mid/low, maybe even the 16 speed. Most 55's had the 8 speed I think.
All had the same engine. More power was due to injector pump settings. Except TN75, which has a turbo.
Lot's more tractor than the TC, but you knew that. Neither one of you are wearing them out (nor am I) with the hours you show. Should fetch a good price.
You didn't mention which version. A, D, S, V, F, etc.
2011 INTERNATIONAL PROSTAR PREMIUM (A52472)
2011 INTERNATIONAL...
2017 John Deere HPX615E Gator Utility Cart (A51691)
2017 John Deere...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A52472)
2013 TEXAS PRIDE...
2015 Honda Civic Engine (A50325)
2015 Honda Civic...
