Pricing on a 2012 L-5040 Grand
   / Pricing on a 2012 L-5040 Grand #1
RichnMo
Springfield, Mo.
Kubota Grand L-5040 GST, Kubota L2900 GST, also have a Case 1840 with loader, ripper teeth, forks, backhoe attachment and steel tracks.
Hi guy's I have been painfully looking for a clean 4wd Kubota in the 38-50 hp range. It would be nice to find a grand series, not crazy about quick attach loader as lifting capacity is more important to me as well as the bucket being closer to the machine. I would like at least 1 or 2 live ports at the rear but not ness. I found a 2012 L-5040 Grand GST,with fluid rear tires, wheel weights, canopy and brush gaurd with 1073 hrs on the clock. What would be a fair price as they are asking 22,000 for it. Thank you in advance or if there are any issues with these units. Rich
   / Pricing on a 2012 L-5040 Grand #2
As you probably know the /40 series Grand L tractors do NOT have Tier IV emission paraphernalia.
$22,000 is a good price in the South, a bargain price in California or the Northeast. With HST+ it might command $24,500.
l assume this L5040 has a Loader. Correct me if I am wrong.
Ok, thank you I will. I live near Springfield Mo. and the tractor is near Nashville. And it's tough to find prices for what the Grand series package costs and I haven't been able to price the HST vs GST but from what I'm gathering are you saying the HST is valued more than the GST? Thank you for any info you have provided.
   / Pricing on a 2012 L-5040 Grand #4
The best feature of the majority of the Grand L tractors is the HST+ (HST/PLUS) transmission.
The Glide Shift is very nice too but not quite as highly valued.
VIDEOS: YouTube
YouTube
Second VIDEO covers evaluating a used tractor.
Kubota L5040
2007 - 2013 L40 Series
Compact Utility tractor
Next model: Kubota L5060
Series next: Kubota L5240
Series back: Kubota L4740
Manufacturer: Kubota
Original price (USD): $28,871 (2011)
Kubota L5040 Engine:
Kubota 2.4L 4-cyl diesel
Kubota L5040 Power:
Engine (gross): 52 hp [38.8 kW]
Engine (net): 50 hp [37.3 kW]
PTO (claimed): 44 hp [32.8 kW]
Capacity:
Fuel: 14.3 gal [54.1 L]
Hydraulic system: 11.9 gal [45.0 L]
Front axle: 9.5 qts [9.0 L]
3-Point Hitch:
Rear Type: I
Rear lift (at ends): 3,680 lbs [1669 kg]
Rear lift (at 24"/610mm): 2,760 lbs [1251 kg]
Power Take-off (PTO):
Rear PTO: independent
Rear RPM: 540
Engine RPM: 540@2550
Mid PTO: semi-independent (optional)
Mid RPM: 2000
Dimensions
Weight: 3,803 lbs [1725 kg]
Wheelbase: 75.4 inches [191 cm]
Length: 126.4 inches [321 cm]
Width: 67.3 inches [170 cm]
Height (ROPS): 98 inches [248 cm]
Ground clearance: 15.7 inches [39 cm]
Front tread: 52.8 inches [134 cm]
Rear tread: 52.2 to 56.3 inches
[132 to 143 cm]
4WD turn radius: 9.2 feet [2.8 m]
Kubota L5040 attachments:
snowblower
blade
front-end loader
backhoe
Loader:
Loader type: Kubota LA854
Height (to pin): 112.3 inches [285 cm]
Clearance, dumped bucket: 88.9 inches [225 cm]
Dump reach: 22.4 inches [56 cm]
Dump angle: 45
Reach at ground: 75.7 inches [192 cm]
Rollback angle: 42
Breakout force (at 500mm): 4,195 lbs [1902 kg]
Lift to full height (at pin): 2,489 lbs [1129 kg]
Lift to full height (at 500mm): 1,878 lbs [851 kg]
Bucket width: 72 inches [182 cm]
Attachment style: J2513 Quick-Coupler (optional)
Raise time to height: 4.2 s
Bucket dump time: 2.3 s
Lowering time: 2.8 s
Rollback time: 3.5 s
Mechanical:
Chassis: 4x4 MFWD 4WD
Differential lock: standard
Steering: hydrostatic power steering
Brakes: mechanical wet disc
Cab: Two-post foldable ROPS.
Hydraulics:
Type: open center
Capacity: 11.9 gal [45.0 L]
Valves: 2 to 3
Pump flow: 9.4 gpm [35.6 lpm]
Total flow: 14.1 gpm [53.4 lpm]
Steering flow: 4.7 gpm [17.8 lpm]
Electrical:
Ground: negative
Charging amps: 45
Page information:
Last update: November 21, 2014
Copyright: Copyright 2016 TractorData LLC
Contact: Peter@TractorData.com
   / Pricing on a 2012 L-5040 Grand #5
You might have some help using the following: tractorhouse.com or machinefinder.com There are others but when you type in one of these they often come up.
2020 Mclanahan 150 TPH USP Wash Plant (A52377)
2020 Mclanahan 150...
2021 JOHN DEERE CP690 LOT NUMBER 196 (A53084)
2021 JOHN DEERE...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2023 SMITH CHALLENGER SCM 400 SWEEPER (A51246)
2023 SMITH...
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
JOHN DEERE 648R LOT NUMBER 108 (A53084)
JOHN DEERE 648R...
