Problems removing front axle seal
   / Problems removing front axle seal #1
moojamboo
Bronze Member
Nothern Vermont
Ford 1710
Today I took apart the front reduction gear box. I have a leaking seal and need to replace it. However i got to this point
This might be novice question but how am i supposed to get the old seal out? I don't want to damage the bearing or race below. any advice on how to get the seal out?
1986 Ford 1710 4WD
So I'm going to leave this for the night and try again in the morning.If anyone has any good ideas how to get this seal out without damaging the bearing below your help would be greatly appreciated.
Thanks in advance,
Matt
   / Problems removing front axle seal #3
G'day Matt just get a flat blade scewdriver and lever out if that doesn't work then drive screwdriver down between seal wall and housing a little then lever out :thumbsup:
Jon
   / Problems removing front axle seal #4
put a long flat tipped pry bar deep under one side of the seal and use the oposite side as the fulcrum and flip it out.
John Deere 960 Culitivator (A50514)
John Deere 960...
2024 AGT INDUSTRIAL QHT-500FL CONCRETE BUGGY (A51243)
2024 AGT...
H & S High Capacity Hayrake (A50515)
H & S High...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2021 FREIGHTLINER 126 SLEEPER TRUCK (A51222)
2021 FREIGHTLINER...
2025 JMR 40in Single Cylinder Hydraulic Grapple Bucket Skid Steer Attachment (A50322)
2025 JMR 40in...
