Backhoe Problems with BT1000 backhoe (Kubota L39) hydraulic hoses failing from ext rubbing
   / Problems with BT1000 backhoe (Kubota L39) hydraulic hoses failing from ext rubbing #1
roanmtsawdust
Johnson City, TN
JD 350B
I have failed two hoses recently where the failure appears to be from the outside in. Hoses were in good condition except where worn. In the BT1000, the hoses proceed through a narrow opening just wide enough for the 6 hoses. If I pull the boom toward the cab, they can pinch the hoses at full retraction. I asked the local Kubota if this was a common problem or have I got a hose routing issue. They were unaware of any issues. Anyone else have this issue? Thanks for any thoughts.
71050 (A49346)
71050 (A49346)
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A50854)
2021 ALLMAND BROS...
2014 Doosan DA30 (A51039)
2014 Doosan DA30...
2019 John Deere 8295R MFWD Tractor (A50657)
2019 John Deere...
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2013 Doyle Dry...
