NormL
Platinum Member
- Joined
- May 9, 2011
- Messages
- 644
- Location
- Manitoba, Canada
- Tractor
- Craftsman GT18, Ford 601 / FEL, Oliver 550 / FEL
Our frequent and heavy snow falls have revealed a fairly serious flaw in the design of my snow clearing equipment. It's a Toro Workhorse 416h with a front mounted two stage blower. The problem I'm having is how quickly I get stuck with it. It has turf tires with chains and weights and over 250 lbs of me for traction. It's shocking how quickly the wheels dig in when I'm not careful. To add to the problem is the lack of clearance under both the front and rear of this machine. The blower attachment has its frame going under the tractor halfway to the back leaving little clearance between that and the ground. The rear of the tractor is similarly close to the ground with its hitch assembly. It gets "hung up" almost the instant the wheels begin to spin and it's time to find something I can use to pull it out. Part of the problem started with the height adjustment of the blower. It always left some snow on the ground which was quickly packed down firmly enough to resist clearing later when I discovered what was happening. That was okay for the first couple of clearing events to reduce the stones and gravel pickup early on. But by the time I realized the snow buildup was still happening, there was already a problem with getting stuck. Also, any bump or rise would amplify when the front wheels rolled over it, raising the blower for a short distance.
For this winter I know I'll have to live with this but I'm looking for ways to prevent a recurrence. First I need to find a way for the blower to follow the ups and downs of the driveway and parking areas. Also, I'm interested in the possible improvement in the rear wheel traction. Tracks come to mind but I understand steering control will suffer without individual wheel brakes. Any other innovations to consider? I have more time than money so I'm looking for something I can modify or fabricate in my shop.
