PT-1850 stability vs tracked skid steer
   / PT-1850 stability vs tracked skid steer #1
60047
Bronze Member
Still searching
Is the PT-1850 with dual tires more stable on undulating terrain than a compact track loader?
   / PT-1850 stability vs tracked skid steer #2
Yes, but different tools for different jobs.
   / PT-1850 stability vs tracked skid steer #3
ASV, and Deere probably have the best slope performance of the skidsteers, but my recollection is that they top out at a 3:1, or 18 degrees for recommended use. While you might get away with steeper, they have two issues; one tipping, and two oil starvation on the engines. Slopes are not the strength of skidsteers. It is a great way to burn up an engine in my opinion.
The 1850 is a 45 degree rated machine. Completely different class in my opinion.
Different machines for different purposes.
All the best,
Peter
   / PT-1850 stability vs tracked skid steer #4
I switched from an ASV RT60 tracked machine to a PT1460 and have no regrets. 1850 with duals should be even more stable. I don't spend much time on real steep stuff, but most of my time is spent on stuff that was pretty spooky on a standard tractor. Undulating terrain is where the PTs shine, articulation and oscillation are confidence inspiring, it's nice to have 4 wheels on the ground. My tracked machine was always rocking over the undulations.Just my .02.
   / PT-1850 stability vs tracked skid steer #5
I looked into renting a CTL to cut a slope. One of the rental companies warned me that if I turned too tightly going uphill, the track could come off and they had a charge to come out and put it back on.
2019 Caterpillar 815K Articulated Compactor (A45336)
2019 Caterpillar...
Lockwood 14ft Even-Flow Box (A47369)
Lockwood 14ft...
2016 KOMATSU WA-470 FRONT END LOADER (A45676)
2016 KOMATSU...
2019 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A45336)
2019 Peterbilt 389...
2019 Chevrolet Tahoe SUV (A46684)
2019 Chevrolet...
2009 Audi A4 Sedan (A46684)
2009 Audi A4 Sedan...
