pto cutting out
/ pto cutting out #1
Fastshivy
Young Harris Ga
John Deere 1023
Hi All
I have a JD 1023e When i am mowing thick grass above 2300 rpms the mid pto shaft that runs the belly mower cuts out. You push the yellow pto button in and pull out to the on position and it works again. The tractor did it about 20 times yesterday. The temp gauge reads about the 1/2 way mark, fins on rad and screen are all clean.
Normal light grass temp gauge reads about 1/3. I am thinking there is a sensor somewhere that is telling the pto to shut down due to engine heat??? Also possible the switch is jiggling off due to rough ride?? Any thoughts would be appreciated.
/ pto cutting out
pto shaft runs to gear box then belt totally an electrical cut out of some kind
/ pto cutting out #4
Hi All
Did you back-up about 20 times yesterday? This may be just a safety trip operating as it was designed to do. You have to push or pull something on the dash before you try to back-up.
/ pto cutting out
Mowed all day at 2800rpms in about 4in grass no problems at all. Temp gauge stayed about 1/3 I think this is heat related. When the temp gauge hits 1/2 problems start. I may be trying to mow grass that is too high.It is an Old fescue hay (about 9-12in) field i mow every 20 days...it is now a subdivision with empty lots. Thinking about a small auxillary electric cooling fan???
/ pto cutting out
Pto still cutting out temp gauge was normal yesterday, but it was in the 90s What else should i be looking at?
/ pto cutting out #8
I think you have an intermittent short some where, possibly the pto switch or the wiring too & fro. Part time problems are a pain to diagnose, good luck.
/ pto cutting out
thanks i think i will replace the switch and see what happens
2012 FORD F-350 SUPER DUTY FLATBED TRUCK (A64276)
2012 FORD F-350...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
2001 16 Ft. Wellcraft Boat w/ 2000 19 Ft. Boat Trailer (A61574)
2001 16 Ft...
2013 Ford Focus Sedan (A61574)
2013 Ford Focus...
(4) METAL TAR BARRELS (A64276)
(4) METAL TAR...
2011 Peterbilt 6x4 Water Truck w 52,000 GVWR, and 2,000 Gallon Tank (A63689)
2011 Peterbilt 6x4...
