PTO extender help
   / PTO extender help #1
AppleMan
Northern IL/Southcentral WI
JD 2305, JD 850, 1951 Farmall
I switched from an self-contained engine driven sprayer, to a pto driven sprayer. My JD 2305 hooks up to the new sprayer, but the overlap of the male and female pto is only about 3 inches (a bit more on the turn). The sprayer manual says it's safe at 2 inches of overlap, but I wanted to extend the PTO hub on the tractor if possible. I saw some extender/adapters at TSC, but wasn't sure if they are meant for this, and if it was safe to do.
I also saw that some ran the PTO at 1000, but I needed to keep it at 560rpm.
Hope this makes sense. I've had the self-engine forever, so using the PTO for a trailer sprayer is new to me and I don't want to ruin the sprayer or tractor...or get hurt.
   / PTO extender help #2
G,day check out the bare co site they have pto extenders that are designed for exactlyyour use but use the bolt clamp type as these are much better on your pto shaft as they do not move and wear the spline good luck with it :)
   / PTO extender help #3
Wow, I hope the sprayer company has good liability insurance. I wouldn't consider using a PTO drive shaft without an overlap of at least six inches.
If your tractor's PTO spline has a pre-drilled pin hole, use this type: PTO ADAPTER 1-3/8 FEAMLE X 1-3/8 MALE - Agri Supply If there's no hole, use this type: PTO ADAPTER 1-3/8X6SPL M. X 1-3/8X6SPL F - Agri Supply . If adding the adapter still doesn't give you a good six inches of safety margin, you might consider replacing the PTO shaft itself
//greg//
   / PTO extender help
Thanks so much. I ordered the extender. It sounded like too short of an overlap. Thanks again!
2007 Ford F-150 4x4 Pickup Truck, VIN # 1FTPX14V37FA94128 (A48836)
2007 Ford F-150...
2016 Ford F-450 Crew Cab Mason Dump Truck (A48081)
2016 Ford F-450...
INOP/NON-RUNNING 1959 Allis Chalmers D14 Tractor (A48837)
INOP/NON-RUNNING...
2019 MACK PINNACLE (A48992)
2019 MACK PINNACLE...
2012 PETERBILT 365(INOPERABLE) (A48992)
2012 PETERBILT...
Ground Hog Mini Trencher (A48837)
Ground Hog Mini...
