PTO hydraulic pump on non-live pto....
   / PTO hydraulic pump on non-live pto.... #1
montejw
NW WA State
1980 AC 5020
isn't going to work, is it? Push in the clutch and the hydraulic system is dead. :( Just looking for more hydraulic flow, maybe a little more pressure.
Monte
   / PTO hydraulic pump on non-live pto.... #2
It will work.. but as you mention.. dies when clutched.. what ya using it for? a backhoe? Should work fine like that.
Next bet is a aux pump if your tractor is setup for it..( for instance my NH is setup to remove a blank plate and add an engine mounted -gear driven- pump.. etc.. ) next than is a front stinger or crank mounted pump, then next would be a do-it-yourself engine mounted pump..like a pow steer pump.. etc..
Soundguy
Soundguy
I'm looking for a little more gpm's, and maybe a little more pressure. 1980 AC 5020, haven't looked for any auxiliary mounting. Probably not there anyway.
Monte
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
New/Unused Gold Mountain Container Shelter 20ft x 40ft (A51573)
New/Unused Gold...
2021 JOHN DEERE 8R340 LOT NUMBER 209 (A53084)
2021 JOHN DEERE...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
