Prince LSR Rapid Extend Logsplitter Valve - Cylinder Services
Not a two stage pump, agree. No two stage valve, disagree. See
http://www.princehyd.com/Portals/0/products/valves/LSR3060Flyer.pdf and
I have a SpeeCo three point hitch splitter powered by the tractor hydraulics. Clearly the tractor represents a single stage pump. Replacing the SpeeCo detent control valve with the the LSR3060 however, is all it takes to make it a two-stage operation.
//greg//
OK, it is two something. Call it two speed valve, or two stage. The data, does not say anything about shifting pressure, however it does increase volume, and that why it is called LSR rapid extend. It can not be used with a two stage pump. It essentially just about doubles the volume of hyd fluid. It lets the operator, manually shift from high speed mode to high splitting force mode. When the lever is first applied, it is in the full force splitting mode, and if you want it to extend faster, the lever is pushed further to the stop point
That pump as stated has a displacement of 9.9 cu in. and is designed to turn at a speed of 540. Whatever engine you add to the pump setup, has to put out 29 HP to get that volume, pressure,and GPM. The tractor had to put out that HP, and so will any engine used in it's place. If you use a 3600 rpm engine, it will have to be geared down to match the PTO rpm of 540. A 9 HP engine can not generate that much GPM.
A .3 cu in pump, at 3000 psi, at 3600 rpm, will pump 4.5 GPM, and require 9 HP
If you use one of those two stage pumps, you only need 5 or 6.5 HP
If you are going to use the current pump, you have to come up with 29 HP.
If you use one of those two stage pumps, you only need 5 or 6.5 HP engine
