PTO Noise
   / PTO Noise #1
racechaser8
Piketon,OHIO
JD 300B & MT160D
I recently bought a mt160D problem is when drivin in any gear with pto in neutral it sounds like its tryin to kick in gear. not always but sometimes. what can be done to fix this ? thanks for the help !! racechaser8
   / PTO Noise #2
Undoubtedly you have 3 PTO speeds. 1 N 2 N 3
Behind the PTO speed lever is a plate that is attached to the tunnel.
The machine screw that holds it stationary to the tunnel when loosened allows the plate to be moved a bit in both directions and is actually the mechanism to adjust the positions of the selector.
Repositioning the plate will assure that Neutral is actually in a neutral location.
In all probability some slop has entered the equation over time and a minor adjustment is called for.
My MT180D needed that fine tuning as well.
And welcome to TBN.
   / PTO Noise
thanks for the info,when i get some more time i will try that ,thanks again. racechaser8
2005 military trailer (A53424)
2005 military...
20" Sea Container (A47384)
20" Sea Container...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2016 FREIGHTLINER CASCADIA DAYCAB (A53843)
2016 FREIGHTLINER...
