PTO not engaging!
   / PTO not engaging! #1
sampey3514
Goldonna , Louisiana
Mahindra 3016
I have a mahindra 3016 manual shift 4x4 tractor- when you engage the PTO, the shaft doesnt turn. Its seems to be going into gear because you cant turn the shaft when you engage the pto. I have checked the fuse and its good . I was wondering could it be a pto solnoid switch . Any ideas???
   / PTO not engaging! #2
I have no idea, but I have a 4010 that has the same problem. I was mowing and then...no grass was being cut. Red light is on showing that the PTO is engaged, fuses are ok, but nothing is turning.
   / PTO not engaging!
Yep thats exactly what mine is doing . Whats really bad is i cant find a manual to work on it !
   / PTO not engaging! #4
I found the problem. I went under the tractor and right below the accelerator pedal is a box on the transmission. There are 2 wires coming from it. In my case one was unplugged, I reattached it and everything worked. The dealer told be there is a button on that box that you can also push and it resets something or other, but since it was awire I didn't get that far. Hope that helps.
Mini Excavator Attachment Set (A50121)
Mini Excavator...
2025 Swict 66in Bucket Skid Steer Attachment (A50322)
2025 Swict 66in...
Diesel Forklift (A51691)
Diesel Forklift...
CFG Industrial MX20R (A50121)
CFG Industrial...
2017 Ford F-550 Ext. Cab Valve Maintenance Vacuum Service Truck (A50323)
2017 Ford F-550...
2021 KOMATSU D39PX-24 CRAWLER DOZER (A51246)
2021 KOMATSU...
