pharmvet
Platinum Member
- Joined
- Sep 28, 2008
- Messages
- 535
- Location
- North East TX
- Tractor
- Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
Both my Wylie manual and coffee shop informants tell me to run some machine oil through my sprayer pump after use to keep corrosion to a minimum. I tried to remove the intake and outlet hoses today by loosening the hose clamps but they were a PITA to remove. In fact, I did not get them removed. This has me thinking. Is there any such brass valve that could be used here between the intake hose and pump that might have a port that could be opened to introduce machine oil into? Maybe then there could be another on the outlet side between the pump and hose that could be opened to allow the oil to drain out without going on down the line. If there is any such beast, please tell me what it called and where to get it. If you guys have come up with any other easy ways to run oil through the pump please let me know. thanks
