PTO shaft has clicking noise
   / PTO shaft has clicking noise #1
Tight
Benton Mississippi
9540 kobuta
I have a 9540 kobuta when clipping and go up a inline a clicking noise come from the pto area. I can shut of pto and restart on level ground and the noise goes a way. This has me puzzled. Any thought?
   / PTO shaft has clicking noise #3
Could your PTO shaft be a bit too long and as the front of the tractor rises the PTO shaft needs to shorten a bit and can't ,so it puts pressure on the PTO at the tractor ?
I have had the tractor and bushhog for 6 years a never had one minute of trouble. This all start at once. The comes from inside the pto housing. I'm going to check an make sure the pto shaft is not binding and slide free. Something I have not checked. QUOTE=amaxwell;4218396]Could your PTO shaft be a bit too long and as the front of the tractor rises the PTO shaft needs to shorten a bit and can't ,so it puts pressure on the PTO at the tractor ?[/QUOTE]
   / PTO shaft has clicking noise #5
Did you ever find out the problem? I have a Kabota L3400HST and was rototilling the ground. There was clicking noise coming from the back of the tractor and my rototiller was not rotating, the PTO shaft was not spinning from the tractor case either. If I raised the rototiller just a little it would spin. Any load put on the pto shaft and it stopped spinning and the clicking noise would be pretty loud. Any suggestions?
Dwayne
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A52377)
2014 MultiQuip...
2025 AGT 750 (A50123)
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
