PTO shaft: How short is too short?
   / PTO shaft: How short is too short? #1
FatTire
Veteran Member
Colorado
Kubota L5740, Unimog 404 w/ snowblower, Deere 620i UTV, MX5100 (sold)
Just bought a CAT 1 chipper off Craigslist. Looks like the PTO shaft will have about 4 inches of overlap at max angle. Is that too short, or what is the minimum for a safe margin?
   / PTO shaft: How short is too short? #3
4" is pushing it. But it also depends on how much HP and what CAT the driveline is.
If it was a cat 4 driveline behind a 20HP tractor with 4" overlap, I think that would be fine.
But 4" on a Cat1 or 2 behind 60 or 70 HP aint gonna cut it unless it was running something like a broadcast seeder.
   / PTO shaft: How short is too short? #4
Some of the PTO shaft manufactures will specify 1/3 of the PTO shafts total length as overlap. I have seen other say 5 inches. Others don't specify the actual overlap, but say leave 1.5 inches of gap when the the spline to spline end is at a minimum as the implement is moved thru the normal arc of its movement. But 4 inches is cutting it thin, and of course how much load is on the shaft would figure into my thoughts. Like was said, if this was a very light load, it might be ok..
   / PTO shaft: How short is too short? #5
I was just checking on the tractor supply web site for the 6' rotary cutter. I thought they had a minimum overlap shown in the PTO cutting section but I couldn't find it. I think the minimum overlap was 4" but I am not sure. If you call a dealer they could probably tell you that is if they weren't more interested in just selling you a new one!
The Bearcat chipper's 3 point is unusually low, so I'm going to make a stand to raise this thing at least 6 inches. This will also straighten out the PTO shaft and I should gain an inch or two. It looks like I will end up near 6 inches on the PTO shaft.
   / PTO shaft: How short is too short? #7
You will likely be OK
   / PTO shaft: How short is too short? #8
That should be fine. There's a big difference in the required overlap with stationary equipment like a chipper or generator and the overlap needed for running a tiller or rotary cutter over uneven terrain.
And also they make "PTO extenders" about $27 at TSC.
SpeeCo PTO Extender - Tractor Supply Co.
/edit Pto Adapter $20 at Agrisupply
Hey thanks for the link to the extension. Didn't even know they make those.
   / PTO shaft: How short is too short? #10
6" should be fine, but if you decide you want/need more, PTO shaft tubing is pretty inexpensive. I think I aid around $39 for a 59" section from Agri Supply recently.
2005 International 7400 Truck, VIN # 1HTWGAAT15J054447 (A44391)
2005 International...
Homemade 6x17 Trailer (A44391)
Homemade 6x17...
1991 International 4900 Box Truck (A46877)
1991 International...
2025 8ft Office Shipping Container (A44571)
2025 8ft Office...
(1) HD 12ft 6in Panel (A44391)
(1) HD 12ft 6in...
Gravely Pro-Turn 260 Zero Turn Mower (A44572)
Gravely Pro-Turn...
