PTO Tiller Questions
/ PTO Tiller Questions #1
lincmercguy
Colorado
JD 5105, JD 5055E
We've decided to hold off on a planter, but still want to expand the garden. The only tiller we have is a very small weed-eater style. I've rented a rear-tine when needed.
I want to buy one, but want to go with a PTO tiller since I have tractors. I'll probably run it with my JD 5105 (45hp). I'm in CO (dry) with sandy soil, no rocks.
One of my questions is on width. Does it need to be as wide as the rear tires? I know that would be ideal, but these have gotten very pricey over the past couple of years. I think the tractor would run a forward rotation 6' or 7', but I see 5' ones for sale once in a while.
My other question is about brands. I know some are built really heavy, but I don't need super heavy duty at this point. I know the mantra is buy once, cry once, but $4k is out of my budget. Any recommended budget-friendly brands? Anything to stay away from?
/ PTO Tiller Questions #2
I’m a homeowner on about about 7 acres in Upstate NY.
Had a 4 ft 3 pt tiller that I ran for my wife’s garden every so often, along with landscaping projects when I first moved here. Used a MF1540 hst (40 hp).
Can’t remember the tiller brand (didn’t use it for a number of years, so sold it).
The tractor tires were a little wider than the tiller; was never an issue.
The tiller was indestructible; hit many rocks and never broke anything. Would just bounce around alot. Did a good job. I think most tillers will be the same.
So…..in my opinion, you will be fine with a smaller tiller. A used one that is not beat up should be fine.
Worst case is that you can just resell it if it turns out you want a bigger one, etc.
/ PTO Tiller Questions #3
I'd suggest buying a used older model that hasn't been abused and left to rot outside. A lot of garden tillers don't get many hours on them.
There are a lot of cheapo chinese made new tillers out there. You get what you pay for. I'd stick with a brand like Landpride.
The challenge is that there are very few used ones around here. There's a Tar River 6' for sale that looks decent, but they still want $2500.
/ PTO Tiller Questions #5
If you do get your hands on a used one, make sure to double check the slipper clutch operation!
/ PTO Tiller Questions #6
I bought a 2+ meter tiller at auction a few years ago for $800 (post with pictures)
Most likely Chinese, but I figured for $800 (plus tax and auction fees it was about $1000) and how much I expected to use it it was worth a go.
First time I used it, a couple tines came off; I bought replacement bolts and lock-tite'd every single bolt (all 108 of them).
It's an absolute beast of a unit, and though my tractor's only got 30 PTO hp, it tears up hard semi-rocky ground quite nicely (I'm not exactly cruising in medium range with it haha - more going a few inches per second at most). Only spins the clutch if I hit a 10+" rock usually. Still I can till a 20x30 patch from scratch with far less effort and better than my rear-tine tiller (which I haven't started since I got this) would've done taking most of the day (multiple passes for depth)
I often see things like this at a nearby monthly auction.
/ PTO Tiller Questions #7
/ PTO Tiller Questions #8
I have a very old sicma or sigma that was at the farm when we bought the farm. It is 6' and works well. Been left outside for who knows how many decades. Still had oil in all the gearboxes.
Slip clutch works well after I took all the bolts loose and freed it up. I think sigma is italian.
Look them up if you get a chance.
/ PTO Tiller Questions #9
I'd guess that a new but cheaper tiller would be the TSC King Kutter brand. And as far as width, I guess you could run it offset if it was narrower than your tire width....just some suggestions.
Cheers,
Mike
/ PTO Tiller Questions #10
I'd have to agree. I bought a new one last time and it's been used 6 or 8 times in 4 years. Tilling the garden just doesn't happen all that much....
/ PTO Tiller Questions #11
Ideally you would want a tiller that is at least as wide as your tires, which would likely mean a 7' wide tiller. I run a 6' forward rotation unit behind a 5075E which is probably a smidge wider than your 5105 and the tiller is a few inches narrower on each side than the tractor. That is not a big deal, but if I didn't have the tiller before I got that tractor, I would have gotten a larger one. If you can find a 6'er for short money but would have to pay a lot more for a 7'er, I would get the 6'er. You will have plenty of power for a 7'er though as your tractor makes a touch over 40 PTO HP.
The tiller I run is a King Kutter and it has been fine. My soil has a large number of rocks and root balls and such as it was a somewhat neglected pasture I plowed under last fall and put a garden in this year. The tiller handled it just fine.
I will say that running a tiller behind a utility tractor does a lot of work in a hurry but you do need a decent amount of space to maneuver it in and a decent sized garden to make it worthwhile to use. I would not want to use my tractor in a garden less than about 75-100' long or with less than about 30' to turn around in on each end, or you will spend more time turning and backing than tilling.
/ PTO Tiller Questions #12
What mo1 said...................
cheers,
Mike
/ PTO Tiller Questions #13
I have a MF GC2400 pulling a 4' Caroni, just slightly wider than the tires, used in a 40' square fenced garden and a slightly smaller food plot for deer. I till the garden twice annually, Spring and Late Summer/Fall. I take down the 7' deer fence on each end to till close to each end where the fence was. With fence down there is plenty of room to turn. The total process takes ~1/2 to 1 hour.
This is the 1st year I've had to adjust the slip clutch after finding a large rock in my deer food plot.
BTW, I'm 78 YO with a quad by-pass, and wouldn't even have a large garden without it.
/ PTO Tiller Questions #14
WHY all the turning?? Your tractor has reverse, doesn't it??
In tight quarters, I lift the tiller, shut it off and back up to start my next pass where I want it.
For tight turns, that's what the individual brakes are for, making tight turns.
SR
/ PTO Tiller Questions #15
I too have been debating this question of getting one and the price has driven me to instead rent. It's $50 for a day rental at my local ACE rental. They put it on my trailer and my tractor takes it off. I use it for the half hour to an hour, maybe do a couple of gardens for neighbors and put it back on. I don't have to maintain or store then. For using it once or twice a year, I think this works best for me at this point. Maybe that's an option for you.
New/Unused Quick Attach Open Back Mounting Plate (A65583)
New/Unused Quick...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2021 Takeuchi TL6R (A64126)
2021 Takeuchi TL6R...
2012 Infiniti G37 Sport (A62613)
2012 Infiniti G37...
2018 Bobcat MT85 (A64126)
2018 Bobcat MT85...
KMC 6-36 3pt 6 Row Peanut Inverter (A64126)
KMC 6-36 3pt 6 Row...
