PTO Water Pump
   / PTO Water Pump #1
SuperDutyDave
Bronze Member
Vermont
Deere 5525 Cab-MFWD Deere 244J Loader
Anyone know where one might buy a reasonably priced PTO driven water pump...only ones I have found have been for huge applications and priced in the $5K+ range!
Can't believe you can buy a good trash pump with good lift and good PSI for around $1K but you can't buy a PTO pump for the same or less...it doesn't have a motor!
Any help would be appreciated...
SD-Dave
   / PTO Water Pump #2
Try asking in the attachments section, you should get more responses as this is not a JD specific question...
   / PTO Water Pump #3
If you are looking for a PTO pump similar to what one would use for a sprayer, you can get them at your local Tractor Supply store. Depending upon what you are looking to do, you can also buy an electric pump and run it off the tractor (Be sure you don't overdraw power from the system). I have a 60 gallon Femco sprayer that I pull with my 2210 that I mounted a electric pump on the front that seems to work just fine.
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2023 JOHN DEERE 8R310 LOT NUMBER 203 (A53084)
2023 JOHN DEERE...
KUBOTA ZD1211 (A53084)
2022 CATERPILLAR 272D3 SKID STEER (A51246)
2022 CATERPILLAR...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
