PTO wires broke help!!
   / PTO wires broke help!! #1
jaceaidan
I have a lt1042 cub cadet. The blade guard came off the pto pulley and ripped the wires to the pto. One of the wires I can connect back together, but the other wire coming out of the pto is too short to reconnect, it's barely hanging out of the pto clutch. I tried to take the pulley off, but the clutch keeps turning. I don't have an air compressor or impact wrench to take it off. Does anyone have any ideas?
   / PTO wires broke help!! #2
You may have to find someone with an impact wrench you can borrow. They do make electric wrenches as well as the air powered ones. If the wire is out far enough that you can touch it with a small soldering iron you can slip a piece of shrink tubing over a new wire and attempt to solder it to the broken one. You can then slide the shrink tubing down to the clutch coil and heat it. In the past I have cut open the covering on coils, dug out the broken wire, soldered an extension to it and taped the coil back up.
Bob B.
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A52577)
2012 INTERNATIONAL...
2015 CATERPILLAR 926M WHEEL LOADER (A51242)
2015 CATERPILLAR...
UNUSED INDUSTRIAS AMERICA 180 HYD SCRAPE BLADE (A51243)
UNUSED INDUSTRIAS...
MODERN MANUFACTURING 8' DISC HARROW (A51243)
MODERN...
2012 Ford Expedition XLT SUV (A51694)
2012 Ford...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A51243)
2012 VOLVO DBL...
