Pug f570
   / Pug f570 #1
Kevin B
Pineville,Mo.
Pug model 570
hello all. I am new here and am hoping some of you are familiar with the Pug f570 4x6. Specifically removal of the transaxle. if any of you can steer me in the right direction I would very much appreciate it.what is the procedure to seperate the axles from the transaxle?
   / Pug f570 #2
Hi Kevin, just saw your post from last month...The person I bought mine from has had to do that on mine.
In a nutshell, you have to remove the bed, then the axle nuts and pins have to be removed.
The nut you have to access, in between the frame and tire, provides almost zero access for a wrench.
My neighbor had a special wrench made by a machine shop just for those nuts but prior to that he was able to remove them but he said it was difficult.
After you remove the nuts and pins the assembly will fall free but there is torque on the assembly that you have to relieve, removing a pin I believe does that.
The axle R/R is relatively simple after that.
Hope I didn't confuse you and if you have specific questions during the process, feel free to contact me and I'll ask him for the answers.
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
Pickup Instructions (A47384)
Pickup...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2012 VOLVO VNL...
