paulharvey
Veteran Member
I am in the Early stages of planning an eventual addition on my doublewide in North central Florida. My original plan was a single bedroom, but really adding a bedroom and spare room isn't that much worse. I plan to do most of the work my self (which you can legally do, just sign a paper stating you are personally doing it, can't sell for 1 year). It will be slab on grade, wood framed, and mostly likely have a 29 GA metal roof on OSB. I know that legally I should pull a permit, and I'm also getting people saying that they just fine you $180 if you dont. Heck, that's cheaper than the BS of doing it legal... I'm also getting people saying that you could have some serious expenses in proving that the unpermited work is up to code, that could get expensive.
I'm not planning on doing crappie work on the house (sheds, etc are another story). I would do a 4" slab with at least a 10"x20" thick edge, with 2-#5 rebar. Walls would be conventional 2x4x92-5/8; 7/16" OSB; ect. All fine for strength. I'm just debating the expense and pain in the butt of getting architects stamps, engineered plans, ect for what is not exactly a complicated build.
Anyone know if there's a loop hole for stamped engineered plans in Florida.
Anyone ever been caught after the fact or during the build where they skipped permitting (come on, we all know that we do it)
Am I worrying too much, and can get a guy to stamp my plans for cheap (12x24 room addition).
Odds of a neighbor calling is zero; odds of a building inspector driving by are Zero. Odds of the county tax man visiting to add it to my taxable square feet; high.
Let's leave safety out of this; I've built many millions of dollars of multi family and commercial buildings as a superintendent for various GCs, it won't be falling down...
No plumbing
Probably 2 20 amp breakers for outlets and llights.
Window unit AC.
If I go "legal" I'll of coarse have to get engineered trusses/if I go "commando" I would price them vs conventionally framed (no idea why they even call it that; haven't seen them site build in 13 years, so how "conventional" is that)
I've built sheds, and porches without problem, just pondering options.
Wife is leaning "commando" for the build.
Earliest I could pour concrete would be tax time next spring.
Edit: simple shed roof with over hang; and structurally independent but attached to double wide
If I do it commando I'll take Many photos to cover my backside somewhat
No plumbing
Window unit AC.
