Pullys on my Kubota belly mower
   / Pullys on my Kubota belly mower #1
Racer11
Mc Louth, Kansas
Kubota 2400 jd 4240
Now that mowing is over for me, I removed my belly mower and cleaned it up and was going to put it in its winter parking spot in my shop. While I was cleaning it up and looking at all the moving parts I noticed that my two outer pulleys have a slight amount of play side to side,,,in other words I can wiggle them a little,,,maybe 5 to 7 thousands,,,just enuf to see the belt pulley move slightly. The mower has about 600 hours of actual mowing time on it, with respect to that I removed one of the pulleys to do a inspection of the bearings and have a look-se.
Now here is my question for anyone who has had a pulley apart,,,,are the bearings tapered or not, ?? and,,I have the pulley stripped down to the shaft and hub assy,,, Does that shaft press out or can I just hammer it out of the hub to get to the bearings and shaft out. And last but not least,,what way does it press out,,,it is splined on one end and the zerk is on the other end.
Hopefully I do not half to replace the hub as a assembly,,,that could get expensive.
   / Pullys on my Kubota belly mower #2
I don't have a clue but it might be helpful to those who do to have a mower model number to better answer these questions. Good luck!
oops,,,,I forgot,,,the mower deck is a Kubota RC54 meaning 54 inch cut
If you can find a parts breakdown it may give you some insite as to how its assembled once you know how its put together its easy to reverse engineer into a pile of separate parts.
Kubota Parts Catalog
They will email you the pdf
bandaidmd,,,,,, Thanks for the link, I pulled it up and found in the parts breakdown schematic a internal snap ring that is holding the shaft and bearings in place,,,It is obvious from that pic the snap ring needs to come out and that will allow the shaft and all to easily be removed.
Thank you very much !!
7021 (A50322)
7021 (A50322)
2007 CATERPILLAR 930G WHEEL LOADER (A51246)
2007 CATERPILLAR...
Dual Cylinder Grapple Skid Steer Attachment (A51691)
Dual Cylinder...
2021 Caterpillar 428 4x4 Extendahoe Loader Backhoe (A52377)
2021 Caterpillar...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
JOHN DEERE TX LOT NUMBER 138 (A53084)
JOHN DEERE TX LOT...
