Purchasing used hydraulic attachments
   / Purchasing used hydraulic attachments #1
Zoombah
Bronze Member
Central Texas
When purchasing used hydraulic equipment (a Gannon 4x2 boxblade with two cylinders) do I just connect it up and get busy or is there anything I can or should do about the hydraulic fluids in the used equipment?
   / Purchasing used hydraulic attachments #2
If it's been sitting outside might contain water. If it's been used regularly, stored inside take a chance & plug & play.
Flushing a couple of cyls and lines won't take much if it looks questionable.
   / Purchasing used hydraulic attachments #3
I would flush the old fluid out unless you know who owned the implements. Just remove the hoses from the cylinders and manually cycle them.
   / Purchasing used hydraulic attachments #4
I believe that I would flush them out. But I would just remove the QD and flush it that way. You can control where the oil goes more easily. If the oil looks good then I would not worry about what is left in the lines and in the cylinders. ;) If it does not look good then pull the lines and clean them out too. In that case you would want to do a more thorough cleaning anyway.:(
Mike
CATERPILLAR 48" QUICK ATTACH FORKS (A51242)
CATERPILLAR 48"...
2012 John Deere 7230R (A52128)
2012 John Deere...
Quick Attach Pallet Forks (A47384)
Quick Attach...
2014 John Deere 544K 2 Wheel Loader (A47384)
2014 John Deere...
New Swict 60" Skidloader Bucket (A50774)
New Swict 60"...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
