Putting a Bradco 11HD Backhoe on a Kioti DS4510?
   / Putting a Bradco 11HD Backhoe on a Kioti DS4510? #1
Ithaca, NY
Kioti DS4510
Looking for some input-Bradco states that this set up should work in terms of hydraulic flow and size of tractor, but the hoe seems a bit big for a tractor that only weighs 3500#. Recommended flow is 11-15 GPM, Kioti putting out 13 GPM. Thoughts or advice would help.
Also, Bradco does not make a sub-frame mount to match any Kioti tractor, so I will be modifying the original sub-frame mount for the Kioti hoe.
   / Putting a Bradco 11HD Backhoe on a Kioti DS4510? #2
That's way more of a backhoe than I would want on any tractor of that size. The stresses that can be transferred from the backhoe to the tractor chassis are my primary concern. Something like a Bradco 508 or the equivalent would be more appropriate.
   / Putting a Bradco 11HD Backhoe on a Kioti DS4510? #3
I made mounts for a Bradco 611 to my New Holland TC 55 DA. The hoe is built super strong and may be a bit too much for the tractor but operating it in a manner it was designed for it works out beautiful. My used hoe was mounted on a Case 1840 skid steer. It was in perfect condition because it was way more machine ( and heavier ) than the skid steer could handle. When I priced a mounting system ( hoe and tractor mount ) I found not only was it more than I paid for the back hoe but it did not have available a sub frame mount that connected the front frame rail. For the price of the shipping ( quoted $350.00 for both mounts ) I bought steel and fabricated a mount I felt that incorporated a proper mounting system. Its not a quick tach but it can be mounted or taken off in fifteen minutes which is not a problem for me.
   / Putting a Bradco 11HD Backhoe on a Kioti DS4510? #4
Somewhere here at TBN is another fellow who put a Bradco 611 on his TC55 and fabricated up his own full length frame mounts. He did a truely fantastic job, and also posted pictures.
I also agree with Rick B whole heartly. That's a big powerful hoe for that size Kioti....
Joes Corvette did it also.
http://www.tractorbynet.com/forums/build-yourself/98777-back-hoe-mount-bradco-611-a.html
Here's the link to a Ford 545 Industrial tractor and a Bradco 611.
http://www.tractorbynet.com/forums/new-holland-owning-operating/117867-added-bradco-611-545d.html
   / Putting a Bradco 11HD Backhoe on a Kioti DS4510? #5
I would be very careful about the mounting frame. If you damage the tractor, Kioti can say it was the hoe & mounting frame fault and you have no recourse (on the basis it is a Kioti issue).
I only say this b/c there's a thread in the Attachment or Operating Kioti forum where Kioti is pointing the finger at the hoe manufacturer (Woods I think?) b/c it isn't a Kioti brand hoe. I haven't heard the outcome but thought I'd mention it as something to keep in mind.
Good luck!!!
2006 Nissan Armada SUV (A44572)
2006 Nissan Armada...
Case 1030 Case Rear Wheel Weights (A47484)
Case 1030 Case...
2020 Chevrolet Surban SUV (A44572)
2020 Chevrolet...
2016 UTILITY VS2DX 53FT DRY VAN TRAILER (A43005)
2016 UTILITY VS2DX...
2025 Wolverine ADB-13-1218R Auger Attachment (A47484)
2025 Wolverine...
Case IH 455 Round Baler (A46877)
Case IH 455 Round...
