Putting in 4wd
   / Putting in 4wd #1
TooTall74
Having trouble getting into 4wd is there any secrets. pushing down on handle but not going into 4wd.
   / Putting in 4wd #2
what model do you have? I can't begin to tell you what it could be but I know with many 4wd vehicles sometimes putting it in reverse for a bit lines stuff up. If you are having that much trouble though something might be broken or misaligned or a bad sensor of some sort? Tell us what tractor you have.
   / Putting in 4wd
it's a 6500 mahindra, I will try the reverse thing tonight and see if that works.
   / Putting in 4wd #4
Somtimes on my 6520, I have to straighten the front wheels and either drive forward a little or in reverse a few feet.
Hope this helps. :)
hugs, Brandi
   / Putting in 4wd
Found the problem, the spline adaptor(connects the gear box with the shaft) lost its set screw and had slide forword. Thanks for all the advise and look forword to tractor time.
Wolverine Quick Attach Hydraulic Winch (A50514)
Wolverine Quick...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
(4) HD 16' Pipe Gates (A50515)
(4) HD 16' Pipe...
Homemade Trailer (A50322)
Homemade Trailer...
UNUSED JCT SKID STEER QUICK ATTACH PLATE COMPACTOR (A51244)
UNUSED JCT SKID...
