Q.) re: 220v welder plugs
   / Q.) re: 220v welder plugs #1
dholly
Platinum Member
Fingerlakes Region, Upstate NY
B7610HST
Wrapping up some garage wiring. I just know -someday- soon I'll have a welder so I want to make a provision for it now before buttoning up the drywall. Sure don't need anything too fancy and/or expensive, most likely just a small buzz box for stick welding, but I see 220v welders can use different type plugs and don't really know why. So if I'm pre-wiring for a future welder, but need a finished receptacle for inspection now, which type receptacle should I use? Is there a 'higher' probability plug config I should be using for a basic 220v stick welder? Thx
   / Q.) re: 220v welder plugs #2
I had a welder circuit pre-wired when we built our house. The panel end is not connected to anything and the outlet end just terminates into an empty two-gang metal work box. A solid cover hides it all. Passed inspection just fine.
If/when I get a welder all I'll have to do is add the appropriate recep and breakers... I hope /forums/images/graemlins/smile.gif
   / Q.) re: 220v welder plugs #3
230v welders normally use a NEMA 6-50R receptacle and a NEMA 6-50P plug. Any good electrical supply house will have them. Home Depot and Lowes usually don't.
   / Q.) re: 220v welder plugs #4
Here in Southern Maryland, Lowes carries the receptacles, but not the plugs, price I got was $8-10 and was about half the local electrical supply. Although that type business tends to have better prices if they know you /forums/images/graemlins/grin.gif
Terry
Thanks for those numbers Mad, I assume from the numbers they are rated 50a and I do have a 50a breaker handy. Sorry to sound so ignorant but, here's where I remain confused...
If I hook up the 50a plug and receptacle you mention using #6 wire, I realize that covers all the bases on the high side, i.e., will never need anything larger. But if I ultimately end up with, say, a smaller 30a welder, I understand that would require a different receptacle and breaker. But what about wire?
For example, seems I could still leave the bigger wire as long as I swap out the breaker and receptacle appropriately? Or would I have to replace the #6 with #10 for 30a, because the 30a 220v receptacle terminals can't physically accept #6 wire?
The more I learn, more I wonder if the best thing is to simply throw an empty conduit to a covered workbox until I actually find that Pennysaver welder special. Sounds like too many variables if'n you don't have a particular welder in mind. The good news is, the plug will be right under the panel box.
   / Q.) re: 220v welder plugs #6
I am not an electrician and I am not familiar with todays codes (although I have a degree in electrical engineering).
However I can tell you this, all the Miller and Hobart 230v welders and plasma cutters and the ThermalArc TA-185 Tig welders and my 20 yr old Craftsman AC buzz box come with NEMA 6-50P plugs. Other manufacturers may be different but I doubt it. That plug/receptacle combination is pretty much the standard for 230v welding equipment regardless of the current rating.
   / Q.) re: 220v welder plugs #7
Most, if not all 220v welders will come with the 6-50p plug on them as Madref said. If buy chance you end up with a welder with a different plug, you can always change the plug on the welder to match the wall, or make a pigtail adapter.
The "standard" receptacle is the NEMA 6-50p, and that is what you should install. My local Home Depot sells them.
Yes, change the plug, that makes sense. Sometimes the simple answers elude you! Thanks all, I see my solution.
   / Q.) re: 220v welder plugs #9
</font><font color="blue" class="small">( The more I learn, more I wonder if the best thing is to simply throw an empty conduit to a covered workbox until I actually find that Pennysaver welder special. )</font>
Too bad you don't live closer to me. I have no more use for my 250 amp Craftsman AC stick welder and I have to upgrade my 3 yr old Millermatic 175 mig to something bigger. Both are for sale, reasonable.
   / Q.) re: 220v welder plugs #10
</font><font color="blue" class="small">( Yes, change the plug, that makes sense. Sometimes the simple answers elude you! Thanks all, I see my solution. )</font>
I have been there!
Use the #6 wire and 50a breaker and never look back!
Wolverine Mini Skid Steer Auger Drive & Bit (A50515)
Wolverine Mini...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
2013 Ford Explorer SUV (A50324)
2013 Ford Explorer...
2013 Mack GU713 T/A Vac-Con Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
