Question about "airplane" tires on shredder???
   / Question about "airplane" tires on shredder??? #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
Last year I bought a Rhino TR120 shredder. Its a 10ft. drag type. It came with 2 rear tires, although there was a place for 2 more (to make it duel). I decided to get 2 more tires so that there would not be any torque on the rear suspension arms. I ordered the tires (spindle, tire and wheel) through my local dealer and they arrived today. I put them on. The new tires are exactly the same brand and size (all numbers match) however they are a taller and a bit narrower. they are Goodyear 24 x 7.5 I assumed possibly the origional tires had "flattened" out a bit. I called my dealer and was told there was no air in these tires. There are, however, air valves in these tires. I tried to air up the old tires but no air would go in.
1) Do these tires take air?
2) Will they flatten out with time?
thanks
   / Question about "airplane" tires on shredder??? #2
My guess is that they are foam filled, and that they will likely not flatten out. How much different are they? Maybe they can be shaved to the same dimeter.
Kim
   / Question about "airplane" tires on shredder??? #3
If it is a foam filled tire & they were filled correctly, they will never flatten out. Is their an issue with weight of the implement? Duals are installed to displace weight and to lessen compaction. If used on had surfaces, the rubber of the tires will wear down, if they are carrying all the weight. That is the problem with foam filled tires.
   / Question about "airplane" tires on shredder??? #4
Yeah, but aircraft tires (especially off something like an F-4 Phantom II) have many more plies then a car/truck tire.
The F-4 tires were 26 plies...take a long time to wear them out (as long as you're not landing the shredder on a flight deck at 150 knots).
   / Question about "airplane" tires on shredder??? #5
ive got aircraft tires on an old shredder,an as far as i know they where never foam filled.just mounted on the rims an put on the shredder.
Would these tires have air stems if there were no air in them? The 2 new ones have some sort of round metal piece approx. the size of a pencil eraser in the middle of the center tread.
   / Question about "airplane" tires on shredder??? #7
my tires dont have air stems in them.
   / Question about "airplane" tires on shredder??? #8
I have aircraft tires on my Supreme 700T Feed Mixer. They are double tuff!!:thumbsup:
   / Question about "airplane" tires on shredder??? #9
We have a set of Goodyear Flight tires on the front of our JD4020 and no more flats. :thumbsup:
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
New/Unused 48in Quick Attach Pallet Forks (A51573)
New/Unused 48in...
Komatsu 330 Excavator (A51573)
Komatsu 330...
2024 JOHN DEERE CP 770 LOT NUMBER 21 (A53084)
2024 JOHN DEERE CP...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
1262 (A50490)
1262 (A50490)
