pharmvet
Platinum Member
- Joined
- Sep 28, 2008
- Messages
- 533
- Location
- North East TX
- Tractor
- Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
I have 2 disks. My john deere has large round axles. I refurbished it over the past year. Because the axle is round, I deduced that the side pressure from the spacers / spools keep the disks from rotating around the axle.
Now I am refurbishing a disk with square axles. There are small grooves in the axles where the blades tried to turn on the axle and scored it. The hole in the blades is not square but rather a strange pattern. Someone suggested to me that the blades were "universal" and made to fit several different axle shapes. Anyway, to my question:
Are blades on square axles kept from spinning primarily by the tightness of the spools on either side, or by the the shape of the axle?
Is it worth welding up the notches in the axle and grinding them smooth again, or is it best to purchase new axles? Also, can you get American Made axles? if so where? thanks
