Question About Draining Fluid From My X300 Transmission
   / Question About Draining Fluid From My X300 Transmission #1
coollx
Bronze Member
Upstate NY
John Deere 2520
Since the K46 transmission has a history of failure, over the winter, I'm planning to change the transmission fluid in my X300.
My tractor has about 30 hours on it and I can tell that after mowing for 45-60 minutes its ground speed slows down a bit. It works fine now but based on what I've read in this forum it makes sense to change out the factory transmission fluid and replace it with the recommended synthetic.
I plan to remove the transmission from the tractor, remove the fill plug then turn it upside down on jack stands and let the factory fluid drain out.
Does anyone know for sure whether doing this will drain ALL fluid from the transmission?
Thank you
165 people read this thread and no one knows the answer?
Someone must have drained the fluid from their X300 series tractor and can offer some input.
   / Question About Draining Fluid From My X300 Transmission #3
There is a complete thread with pics on this trans.
   / Question About Draining Fluid From My X300 Transmission #4
From what I've heard, you cannot completely drain the trans without splitting it. I'm not sure about the K46 but for the K58, there is a kit that you can install consisting of 2 drain plugs (you have to split the trans, drill 2 holes in specified locations, tap the case for threads, then put in the plugs). It sounds more complicated than it really is since when you split the case it means removing the bottom cover while everything stays in place in the transmission. You might want to read up on it here: http://www.mytractorforum.com/showthread.php?t=179552&highlight=drain+plug+install
There is a great bunch on this forum:
http://www.mytractorforum.com/forumdisplay.php?f=12
   / Question About Draining Fluid From My X300 Transmission #6
Thank you
From my experience, draining and replacing the fluid in a K46, be it an L130 or X300, will not likely result in any long term benefit. Those that have told me they have done so have said it basically is a waste of time. If the K46 is beginning to fail, you really have only three choices: Replace, Overhaul or Upgrade. With the first two options you can reasonably expect to get about the same service as before. Others may have different results.
/roger - RJR Tractor LLC
2011 PJ Tilt Deck Gooseneck Trailer (A50514)
2011 PJ Tilt Deck...
Mayrath 10 x 32 Auger (A50514)
Mayrath 10 x 32...
UNUSED MOWER KING ECSSCT72 TRENCHER (A51244)
UNUSED MOWER KING...
NEVER USED FECON 74in Deck Mulcher FDM74 (A52128)
NEVER USED FECON...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2000 Ford F-650 TMA Attenuator Truck (A49461)
2000 Ford F-650...
