Question about temperature gauge reading on L3400
   / Question about temperature gauge reading on L3400 #1
Spacefarm
Virginia
Kubota L3400 & JD 325
Even after running for over an hour the temperature reading on my L3400 is just very slightly above "C" on the temperature gauge. Does anyone know if this is correct? Seems to me the needle should be somewhere in the middle of the range.
Thank you
   / Question about temperature gauge reading on L3400 #2
That is a about the same as my L3400. The temp gauge barely moves. Gets to the small dot on the lower right side. I think this may be normal temp. I've only got about 25hrs so far.
   / Question about temperature gauge reading on L3400 #3
My L3400 also shows very little movement. Just above the dot. We have not had any warm weather as of yet to see how it will respond then.
   / Question about temperature gauge reading on L3400 #4
Mine is the same way.
   / Question about temperature gauge reading on L3400 #5
My L3400HST is the same. I posted about that last year and it seems normal.
   / Question about temperature gauge reading on L3400 #6
The low reading is normal on most all <font color="orange"> Kubota </font> "B" and "L" series tractors. When the screen starts to get plugged with dirt and other material the gage will start to move up. It is time to clean screen in front to radiator.
My thanks to everyone to responded. Looks like the temperature reading is pretty normal.
Larry
   / Question about temperature gauge reading on L3400 #8
I'll second Ron's post. Kubota's run cool on the guage until the screen gets clogged up. You notice it in the late summer and fall when cutting tall grass and weeds, the seed pods and stuff will clog the air intake holes and the screens. 5 min of R&R and the temp drops.
Also, Diesels run cooler than gas engines. That's one reason they are so good at constant high load applications.
Enjoy your tractor!
jb
PALLET OF GOLF CART TIRES (A51248)
PALLET OF GOLF...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2017 Bayliner VR5 21ft Bowrider Boat with 29ft T/A Boat Trailer (A51694)
2017 Bayliner VR5...
PAIR OF 5' CLIP ON TRAILER RAMPS (A51247)
PAIR OF 5' CLIP ON...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
2010 Ford Escape Hybrid SUV (A51694)
2010 Ford Escape...
