Dargo
Super Member
- Joined
- Mar 6, 2004
- Messages
- 5,981
- Location
- S. IN
- Tractor
- Jinma, Foton, TYM, Belarus, Yanmar, Branson, Montana, Mahindra and maybe some green and orange too.
Is it normal for an electric meter, from the utility company, to run with nothing attached to it? I haven't had a chance to wire up much in my newer barn and when I added it my utility company had to run another drop from the transformer to it because I was already using all of the 600 amp service run to my home and I wanted to put 200 amps to that barn. Anyway, it's a completely separate run with it's own meter. Since not much is attached to it except one outlet, two vehicle lifts (wired direct with their own breakers), overhead lights, 2 outlets for welders (nothing attached to them currently) and a dusk to dawn light (similarly with it's own breaker).
For some reason I looked at the meter a couple of days ago and noticed that the meter was slowly turning when nothing was on. I figured no big deal and that I likely had something with a transformer plugged into the outlet inside such as a cordless tool battery charger. Upon further inspection, nothing was plugged in. Getting more curious, I flipped all breakers off and looked again; still turning. Hmm, since I had the cover off of the panel, I pulled the 200 amp breaker out of the box, leaving absolutely nothing attached; still turning. Is that normal?
It's a really, really simple setup with the utility company riser coming up on the outside of the barn with a meter on top of it and my breaker panel directly on the other side of the meter inside the barn. Nothing else is fed from that run and nothing is attached to it now. Still, the meter makes 3.8 revolutions per hour, every hour, with nothing attached. What am I missing? That just doesn't seem right to me. With no panel attached and nothing but what the utility company sitting there shouldn't the meter be motionless? I can't help but wonder...
