Loader Quick Attach for 67 Series Loader
   / Quick Attach for 67 Series Loader #1
Mike68
Bronze Member
Granby CT
John Deere 750
Has anyone had any luck getting a quick attach mount that fit the 67 series loader arms? I have a JD 750 with the 67 series loader. I want to convert the pin on style bucket to QA so that I can make use accessories such as pallet forks and a snow blade easily.
As I understand it the centerline distance between the loader arms would be different than a standard QA equipped tractor. That should be OK as I would just compensate when I put the QA brackets on my bucket, etc. I just would not be able to borrow QA attachments.
I am more concerned if the QA mount would fit on the end of the loader arms(width) and if the pin diameter and spacing would be same.
   / Quick Attach for 67 Series Loader #2
:welcome:
   / Quick Attach for 67 Series Loader #3
I've got the same question about a quick attach for the 67 loader on my JD750.
Figured I'd give this thread a bump and see if there was any new info out there.
   / Quick Attach for 67 Series Loader #4
There is a manufacturer called HLA in Ontario. They build all kind of loader attachments and adapters.
   / Quick Attach for 67 Series Loader #5
Worksaver makes many QH adapters, but the main killer for the 67 will be adding the additional weight and moving the attachment out further. I'm thinking the #832655 plus the pin-on bracket they mention to adapt it, your looking at adding an additional 150 pounds though before you even add an implement.
Attachments Using Quick Attach System
   / Quick Attach for 67 Series Loader #6
Thanks for the replies, folks!
@kennyd, really good point about the increased weight and the distance of it from the pivot - I hadn't thought about that. With that loader and small tractor, I'd guess that it would really limit the utility for the loader.
2020 Dodge Durango SUV (A44572)
2020 Dodge Durango...
Kobelco SK200SR LC Excavator (A47484)
Kobelco SK200SR LC...
2025 Wolverine PT-16-01C 3-Point Quick Hitch (A47484)
2025 Wolverine...
2016 Mahindra 1526L 4WD Front Loader Tractor (A44571)
2016 Mahindra...
2012 Bomag BC572 Refuse Compactor (A44571)
2012 Bomag BC572...
2025 AllMetal K3325 UNUSED Double Garage Metal She (A47484)
2025 AllMetal...
