Quick Attach mounting plate
   / Quick Attach mounting plate #1
abunchofidiots
Bronze Member
Mt. Sidney, VA
Yanmar YT 235
There seems to be a large variance in the dimensions of quick attach plates. Most show the width needing to be 44 to 45 inches. The vertical seems to vary wildly from 15 to 18 inches. Being an ISO standard, I'm surprised it is not described better.
   / Quick Attach mounting plate #2
I would think the distance between the top slot and the lower pin slots is the critical dimension regardless of the OA size of the plate.
   / Quick Attach mounting plate #3
If you're talking about skid steer quick attach plates I have purchased two from different vendors on Ebay and they both fit fine. They are two different thicknesses.
   / Quick Attach mounting plate #4
I have ordered 3 SSQA plates through Ebay, purchased a set of pallet forks, and borrowed the forks and buckets off our skid steers at work and all fit my tractor fine.
Never seen or ran into an issue with different height SSQA plates.
2013 Ver-Mac Solar S/A Towable Trailer Message Board (A49461)
2013 Ver-Mac Solar...
2007 MD-8 TRIPLEX PUMP POWERED BY 1050HP MTU ENGINE (A50854)
2007 MD-8 TRIPLEX...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2017 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2017 Ford F-450...
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
1994 FORD F450-SUPER DUTY FLATBED (A51219)
1994 FORD...
