quick attach trimmer problems
   / quick attach trimmer problems #1
OKnewguy
Platinum Member
Edmond, Oklahoma (OKC)
Jinma 224
Well I have a problem, and thought I would pick the collective brain of TBN. My new (1 season old) troybilt trimmer stripped out the quick attach coupler while running a hedge trimmer. I guess the hedge trimmer is to heavy duty for some of these trimmers. The female square coupler just stripped out and is now round. I have been racking my brain and have not come up with a way to fix this (the replacement part is a whole assembly and is pretty expensive). AND THEN to top it off, I was using my ancient ryobi with the same hedge trimmer and I sheared the drive cable on this one. Any ideas would be a great help on how to remedy either one of these. I now have 2, 2 cycle engines if any one wants to wheel and deal? /forums/images/graemlins/smirk.gif
Thanks, Dave
   / quick attach trimmer problems #2
Dave, buy a good commerical grade unit & don't waste the money to repair these units.Not to cut your units, but they are throw away home owner grade light duty / use units.
   / quick attach trimmer problems #3
Ironic that the "weed wheels" ad popped up right under your 'throw away home owner' comment. At times I think those wheels would be a good idea, but think they would be heavy to lug around and in the way most of the time. But don't really know that.
(Must be a new 'ad' gimmick that pops up).
   / quick attach trimmer problems #4
I didn't see that . Is that one of those ads at the top of the page?
I know I should get a good one, but my little ryobi 725 (?) has been running strong for 8 years now. I will end up getting a good one, but now I have these 2 motors that are just sitting there. It drives me crazy I can't think of a good way to get them going.
So the questions is: What should I spend, and what brands. Echo, stihl or simular? Are there any at the the big chains that are worth a flip?
Thanks, Dave
   / quick attach trimmer problems #6
Try this site . You can always donate them to the good will. They have people there that repair things. they may have several already donated & they can make 1 good 1 out of several bad ones. Also a good tax deduction. Not many of those still left these days.
   / quick attach trimmer problems #7
I'd think the Cultivator is a lot higher duty than a hedge trimmer. Never stripped it or broke the cable on either the Ryobi or the Cub Cadet drive.
Problem I had in going to a Stihl or anything else is all my Ryobi add-ons wouldn't work. So, I bought the Cub Cadet. In between, I bought a slightly cheaper TroyBilt (actually MTD now) on that refused to start after the first use. Took it back for a full refund at Lowes. It didn't have any adjustment to the choke: all automatic. The Cub Cadet (think it's also MTD) does have a manual choke. It starts instantly now with choke on, full throttle and a shot of starting fluid.
Saw a Shindawa drive at a local dealer that may be heavier duty and looks like it MIGHT take the Ryobi type add-ons. Was considering it until I discovered the Cub Cadet.
Ralph
I am in the same boat, I have tons of attachment. I was talking to my neighbor, and he had bought a troybilt also and returned it when the motor locked up after about 20min of use. I might check out the Cubs.
Thanks, DAve
   / quick attach trimmer problems #9
I have an old Ryobi 720 model trimmer with quick attach. It was a great trimmer, lasted many years. I still have it and it runs, just very rough. I bought a Stihl FS 110R last summer with the 4-Mix engine. Fantastic trimmer, lots of torque. I also got the pole pruner (mini chainsaw) and 3 pointed star blade attachments for it. I am very happy with the Stihl. I also have a Stihl chainsaw.
Well thanks for the info on the stihl, I have not been able to find any of the higher end brands with the quick attach option. I will admit I have not looked extensively thou. I really need to get one with the q. a. because I have a large assortment of attachment also. In general I like the idea of mantaining fewer engines, but when your down, your down on all of them.
Thanks Guys, DAve
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2008 INTERNATIONAL WORKSTAR 7400 SFA 6X4 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
MINI GOLF CART (A53843)
MINI GOLF CART...
2020 KUBOTA RTV...
2017 HITACHI ZX350LC EXCAVATOR (A53426)
2017 HITACHI...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
