All, I'm looking for your opinions on quick attach options for my Mahindra 6500. I need to easily switch between bush-hog, sprayer, box-blade, etc. Thanks..KK
I saw on tractor data your tractor is cat 1 and cat 2 on the 3 point hitch. What are your implements? Are they quick hitch compatible? If you want a cat 1 quick hitch the John Deere imatch is the nicest for the money IMO. If you want a Cat 2 the Land pride QH20 looks good. With a quick htich you will need bushings for the lift arms pins and toplink pin need to be bushinged up to Cat 3. Once you get your implements set up for the quick hitch hooking up will be a breeze.
