radio install for CT450
   / radio install for CT450 #1
mflick3
Got a bobcat 450 today with cab. The cab has slot for radio and is supposed to be auto radio ready. It looks like two white push connector plugs unmarked and antenna cable behind slot cover. But no info in manuel on what socket wiring is, I expect one may be for power and the other for the speakers but not sure. I got a jvc kd-r210 from best buy and it has wiring diagram with wires but not a socket plug so not sure it will work without knowing which wire goes where on bobcat plugs.
I see a number of wiring harness kits at bestbuy for ford, etc but nothing for bobcat does anyone know which car kit might work with the bobcat plugs?
   / radio install for CT450 #2
Not sure bout the radio install but welcome to the Bobcat family. You got an awesome tractor!!:thumbsup:
Found answer from dealer. Needed to order radio cable from bobcat about $21. Gives standard wire colors that match radio wires, just needed to connect the wires and plug in the antenna.
(3) 40 RIG MATS (A50854)
(3) 40 RIG MATS...
John Deere Quick Attach Pallet Forks (A50514)
John Deere Quick...
2003 MACK RD6885S T/A DUMP TRUCK (A51406)
2003 MACK RD6885S...
John Deere 637 Disk (A50514)
John Deere 637...
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
2003 Lincoln Aviator (A50515)
2003 Lincoln...
