rake with blade to remove snow?
   / rake with blade to remove snow? #1
bellweather
Platinum Member
Western MA
Kubota BX22
I have access to a 60" Land Pride rake with flip-down blade and gauge wheels. I was thinking of getting it for snow removal (along with FEL). What appeals to me is the fact that I can angle the rake/blade which I assume will push the snow off to the side. Any thoughts on whether this would be a good setup? Thanks.
   / rake with blade to remove snow? #2
Forget who it was, but he had good results with just using the rake... the flip down blade would be extra nice :thumbsup: (when you get it, post some photos, it sounds like a neat implement).
   / rake with blade to remove snow? #3
I've used a rake to move snow. It worked very well, especially when I clamped a full length piece of U-channel on the tines. It acted as a scraper and also kept the gravel from being lifted. Later on, I added a piece of 2x8 to the rig as a backboard to keep the fluffy snow from leaking through the tines. The channel + board deal allows you to have a rear plow that's wider than the rake actually is because of how much wood you want to acquire.
Necessity is the mother of invention.
great idea attaching a board! Do you use gauge wheels or just allow the board to float?
   / rake with blade to remove snow? #5
The tines of my rake get clogged up almost immediately, with the wet snow we get around here. It works almost the same as a blade. I don't have gauge wheels, but if I did, I'd set them to stir up a bit of driveway-gravel into the snow that remains after I've gone over with the rake.
   / rake with blade to remove snow? #6
I have a 72" rake that does a good job moving light snow loads. I like the combed finish a rake leaves on the snow compared to a blades smooth finish. Much better for vehicle traction.
What size tractor do you have? Just note a 60" blade on a 30 degree angle has a usable width of about 52". Make sure this is a good size match for your tractor.
   / rake with blade to remove snow? #7
JohnDeere3720 uses a rake...
   / rake with blade to remove snow? #8
I used to have a rubber cutting edge I bolted on the back of an 8 foot rake. I really thought it worked good, I never angled it though. I also had a 100 pound weight strapped on it for down pressure. This was on my JD 3720.
(6) HD 12' Pipe Gates (A50515)
(6) HD 12' Pipe...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A52128)
Michelin CARGOXBIB...
UNUSED FUTURE MINI SKID STEER HYD 12" AUGER (A51244)
UNUSED FUTURE MINI...
UNUSED FUTURE MINI SKID STEER HYD HAMMER (A51244)
UNUSED AGT MX12RX EXCAVATOR (A51243)
UNUSED AGT MX12RX...
2016 Chevrolet Impala LT Limited Sedan (A48082)
2016 Chevrolet...
