Oil & Fuel Ran out of fuel - Kama 454
   / Ran out of fuel - Kama 454 #1
rhallman
Just ran out of fuel on my Kama 454. I tried pulling the Injector lines off of the Injector pump and used the primer pump on the injector pump, but I am not seeing any fuel come out of the injector line outlets.
What else do I need to do to prime the system again?
Thanks...
Rich
   / Ran out of fuel - Kama 454 #3
The hand primer will not push fuel through the injection pump, only to the injection pump. As Harry says, start with a full filter housing - that will save a lot of pumping. With the filter slightly loose, pump until fuel spills down the side - then tighten filter.
From that point, you have to use the starter motor. It turns the flywheel which turns the crankshaft which turns the injection pump which pushes fuel up the hard lines. Crank the engine till you see fuel coming out at the injector end of the hardlines, then tighten them down - it should then start
//greg//
   / Ran out of fuel - Kama 454 #4
Bummer... I am not specifically familliar with your tractor, but you may have a bleed nut on the top of the filter housing to vent the air. You may also have a bleed nut on the top of the injector pump to get all the air out of the injector pump housing. My Jinma actually has a ring thru the head of the bleed screw on the pump housing so it can be opened without tools. You need to get all the air out of the system up to the injector pump housing using that hand pump. Once you get the air out of the filter housing and the pump housing, it can be a good idea to go back and vent the filter housing again. If the filter is above the injector pump, sometimes purging the pump housing will allow air to go back up to the filter housing. It is important to get ALL this air out of the line feeding the pump before going on to the hard line purging.
Once this is done, as mentioned crack the injector hard lines at the top and crank the engine till you get fuel out of those fittings. A white rag wrapped around the loosened fittings is good for this as it will quickly show the fuel and help contain the mess. If you have a compression release, using it will save some wear on the battery and starter while you crank the air out of the hard lines.
Once you get fuel out the top, snug down the hard lines and she should start. It may run a little rough for a little while untill any final air bubbles work loose. Any cylinder that dosn't fire still has too much air in the lines for the injector to crack. Sometimes tapping the lines with a screwdriver handle can help work bubbles loose.
Good Luck
2019 KOMATSU WA320-8 WHEEL LOADER (A51246)
2019 KOMATSU...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53472)
Michelin CARGOXBIB...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
INOP/NON-RUNNING 2006 Mack CV713 Granite Truck, VIN # 1M2AG11C56M039887 (A51572)
INOP/NON-RUNNING...
