Rattling sound when in high gear on Max 25 HST
   / Rattling sound when in high gear on Max 25 HST #1
swclemons
Hazard,Ky
Mahindra/Max 25
After several days of heavy usage this weekend my Max 25 started making a odd rattling sound. What I found was one of the two bolts holding the cover on the front driveline u-joint was missing and the other was almost backed out. I removed the cover and couldn't find anything wrong with the u-joint. I replaced the missing m6x12mm bolt and tightened everything down. No more rattle now. The two bolts didn't have lock washers or thread locking compound on them, which I found odd. Has anyone else had this issue?
Thanks!
   / Rattling sound when in high gear on Max 25 HST #2
Iv had a similar issue a couple of times with the 3016 and a 24.. did the same thing to fix... wouldn't worry bout it you got it fixed
   / Rattling sound when in high gear on Max 25 HST #3
guess i need to look under mine
   / Rattling sound when in high gear on Max 25 HST #4
Yes sir.
Max 24 just turned two years old this month and this summer I thought the front drive shaft was coming apart with all the noise.
Lucky for me the bolts and nuts had not fallen off and I was able to tighten the shroud.
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
SAKAI SV510 SMOOTH DRUM ROLLER (A51242)
SAKAI SV510 SMOOTH...
UNUSED AGT MH12RX EXCAVATOR (A51243)
UNUSED AGT MH12RX...
2012 Volvo XC70 Wagon (A50324)
2012 Volvo XC70...
Best 30' Grain Drill (A50514)
Best 30' Grain...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 84"...
