RCF2072 cutter shroud removal or greasing technique
   / RCF2072 cutter shroud removal or greasing technique #1
Aggie66
Bronze Member
Rockdale TX
MX 5400
im needing to grease the rear ujoint on my shredder. The shroud with the hole and side doors doesn’t make it any easier. Also if I want to slip the clutch the side doors are difficult. Has anyone removed the shroud and can explain how to do it. If I could take the rear shaft off I’d do that but I think it’s hard attached. Any experience or suggestions on how you do this or what kind of grease method is welcome. I guess I’m just ignorant of how that shroud was installed. Can’t figure it out. Thanks
   / RCF2072 cutter shroud removal or greasing technique #2
Curious to learn how it can be easier, but I have been able to both grease the u-joint and slip the clutch on this cutter just using the side doors.
I do take the cover off the PTO shaft itself though (there are the three plastic fastners you can rotate 90deg with a flathead screwdriver, pull off, then remove/move the cover for the end of the PTO shaft).
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2014 John Deere 6125R Utility Tractor with loader (A50657)
2014 John Deere...
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
Adams 5 ton Fertilizer Buggy / Wagon (A51039)
Adams 5 ton...
2007 MD-8 TRIPLEX PUMP POWERED BY 1050HP MTU ENGINE (A50854)
2007 MD-8 TRIPLEX...
Hydraulic Breaker Excavator Attachment (A49461)
Hydraulic Breaker...
