Re: Installation of Winter heater for coolant
   / Re: Installation of Winter heater for coolant #1
dmedalen
Cub Cadet LX450TL
I have a new Cub Cadet TL450LX with a 4-cyl. Yanmar engine. I love it! I would like to mount a circulating coolant heater on it but I am not sure if I will be able to purchase metric-threaded hose fittings to mount on the engine block and thermostat housing. Does anyone have any suggestions??? I am hesitant to mount a heater in the 1" lower radiator hose as the closed thermostat will likely severely restrict the circulation of the coolant. Or have any of you out there found a rad hose heater more than adequate??? I would welcome any suggestions.
   / Re: Installation of Winter heater for coolant #2
I think you mean LX 450? If so you probably have the Yanmar 4tnv88 engine, same as mine.
Here is the screw-in block heater for the 4tnv88: ZeroStart - 310-0003 - Freeze Plug Engine Heater , 400W 120V
Its not metric and it works very well. I plug mine in about an hour before starting it in the winter. You'll want to heat the plug with a propane torch before attempting to unthread it. After heating the plug I used a 1/2 inch impact gun with light taps on the trigger until I saw the plug start to turn, then backed it out from there with a breaker bar. If you're quick you can swap out the plug with the block heater and not loose more than 6-8 ounces of coolant. If you attempt this, don't forget to put teflon tape on the threads of the block heater before installing it. Good luck!
More info here: http://www.tractorbynet.com/forums/yanmar/258437-4tnv88-block-heater.html
Yes, you are very correct. It is a 2011 LX450TL. Thank you. (Great tractor so far). And I will search out the heater. Thanks again.
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
72In FEL HD Round Back Bucket (A53472)
72In FEL HD Round...
KMC 5610 (A53084)
KMC 5610 (A53084)
