Re: TS1910 injection pump
   / Re: TS1910 injection pump #1
Kiona Farm
NW North Carolina
Iseki TS1910
My injection pump is leaking where the tach drive connects to the pump allowing oil to run into the cable housing and leak out where the housing is cracked. So far the leak is not so bad that I can't use tractor but I am afraid that it could suddenly get worse and ruin the pump. Is there a possible fix that does'nt require injection pump rebuilding or replacement?:confused:
   / Re: TS1910 injection pump #2
I guess it all depends on how much pressure you're talking about. With good surface cleaning and prep I would think using JB-Weld would be worth a try. The stuff is just amazing.
J-B Weld Company - Products Overview
   / Re: TS1910 injection pump #3
I vote for the JB Weld. I repaired a crack on my old Ford tractor years ago and it's still holding.
Jim
   / Re: TS1910 injection pump #4
Replace the tach cable and/or the housing. I could be wrong, but I believe that is designed that way to lube the cable. When the white metal threaded end of my tach cable broke, I got the same leak. Replaced the tach cable two years ago, viola, no more leak.
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
24' Free Standing Panel with Swing Gate (A50515)
24' Free Standing...
Woods LR72 72" 3pt Rake (A50774)
Woods LR72 72" 3pt...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2025 Kivel 48in...
